IAT promblem
Old Jan 15, 2007 | 08:55 PM
bluebody's Avatar
bluebody
Default IAT promblem
Went to tune my car and the IAT sensor isnt working. (intake air temp.)
located on the intake... I installed a new sensor still didnt work so it must be wiring anybody have any ideas???
Old Jan 15, 2007 | 09:35 PM
chuckster's Avatar
chuckster
I am assuming you know for sure it's not working? You have codes or you are registering a very cold number if you are logging...
Apparently some people have had wire breakage inside the insulation...check for solid continuity with an ohm meter.
Old Jan 15, 2007 | 10:58 PM
VetteDrmr's Avatar
VetteDrmr
bluebody,
Since you were going to have your car tuned, I'm assuming you were able to monitor the IAT and seeing a very cold temperature, roughly -34 degrees F? If that's the case, you've probably got a broken wire in the harness right before it goes into the connector (at least I'm 3 for 3 in the past year). Try the good ole wiggle test.
HTH, and have a good one,
Mike
Old Jan 15, 2007 | 11:47 PM
bluebody's Avatar
bluebody
What should i do it does say -38. Take off the black loom? how far does the wire go back?
Old Jan 16, 2007 | 03:17 PM
dperretti1's Avatar
dperretti1
Had same problem, it was the connector. You can get one at the dealer. It's pretty easy to replace. When I checked the connector the problem was in the connector itself not the wire, so you should not have to replace much of the wiring. The new connector comes with more then you should need.
Old Jan 16, 2007 | 09:57 PM
VetteDrmr's Avatar
VetteDrmr
Get a new connector at your GM parts dealer, should be around $15-20. You'll probably find the break in the wire is close to the connector.
Mike
Old Jan 16, 2007 | 10:30 PM
bluebody's Avatar
bluebody
the connector as in the sensor that plugs into the intake? if so i replaced it already.
Old Jan 16, 2007 | 10:31 PM
chuckster's Avatar
chuckster
No the connector as in the plug that connects to the IAT sensor mounted in the Air bridge..
Old Jan 17, 2007 | 06:12 PM
bluebody's Avatar
bluebody
ttt
Old Jan 17, 2007 | 10:41 PM
chuckster's Avatar
chuckster
ttt
The IAT sensor is mounted in the side of the airbridge.. If you disconnect it... you will see 2 little pins sticking out of it.. The connecter that plugs on to those pins is what needs to be tested..
Old Jan 18, 2007 | 12:02 AM
C5-vette's Avatar
C5-vette
I had the same problem. I replaced the harness part #12102620 and this took care of it, no more problem.
To IAT promblem
