my wife wants to get me a good craftsman tool set as an anniversary gift for the once in a while that i do work on my 03 coupe. any suggestions on a good kit to go for?
1st - your wife wants to buy you tool?? Does she have a sister?
I picked up a 180pc mechanics tool set off ebay years ago. It's served me well. If you don't have a lot of tools now, i'd start with something like this
you need both metric and standard stuff, that set should get you through 80% of the basic maintenance jobs and you'll just have to pick up occasional sockets and tools for some of the odd fasteners (T-47 for the seatbelts for example)
look here for more options depending on your budget
this is the one i have and love it...it has had everything that i have needed for both my 66 and 2000 coupes.... absolutely perfect!
Sully
Great set, what I have. The red plastic drawers will come out of that, and you can drop two length ways into the medium height drawers on most small tool chests, PERFECT.
Things I got after that right off the top:
Torx head socket set
Fuel line disconnect set
Gear-rachet box and open end (std and metric)
Here is what I keep in the car. I'd suggest starting with a nice small Craftsman (or Mac or Snap-On) set, and add a little every month. You'll need a tool box also.
4 way screwdriver
Offset screwdriver
Large screwdriver (common)
Pry bar
Torx bits
¾ socket set (SAE & Metric)
Hammer
Zip ties
Tape
Tire gauge
Flashlight
Tire patch kit
Channel locks
Pliers
Needle nose
Vice grips
Wire cutters
Wrenches
Jumper cables
Rags
Allen wrench set
Knife
Spare belt
WD-40
Window cleaner
Cleaner
Gloves
Oil
Zip lock bags
Wool blanket
$20.00
4 way screwdriver
Offset screwdriver
Pry bar
Torx bits
Hammer
Zip ties
Tape
Tire gauge
Flashlight
Tire patch kit
Channel locks
Pliers
Needle nose
Vice grips
Wire cutters
Wrenches
Jumper cables
Rags
Allen wrench set
Knife
Spare belt
WD-40
Window cleaner
Cleaner
Gloves
Oil
Zip lock bags
Wool blanket
$20.00
