Automatic Transmission oil cooler
Old Jan 16, 2007 | 02:09 PM
BlueDragon's Avatar
BlueDragon
Default Automatic Transmission oil cooler
I am upgrading my tranny to an RPM level 4. What is a good brand oil cooler to run with it?
Old Jan 16, 2007 | 02:20 PM
billiardcue's Avatar
billiardcue
RPM put an inexpensive cooler from NAPA on my car when they installed the level 5 transmission last year. It runs from the 140s in the the winter to 180s in the summer.
Old Jan 16, 2007 | 03:20 PM
oldschoolvette's Avatar
oldschoolvette
B&M coolers are nice and they come with everything needed for the install. They are also very good quality.
Old Jan 16, 2007 | 03:23 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I have the same tranny with the B&M and it runs the same as billiardcue temps. Can't go wrong with a cooler, that is for sure.
Old Jan 16, 2007 | 03:41 PM
hotwheels57's Avatar
hotwheels57
The B&M RACING stacked plate coolers are better than the old style tube in fin design...more cooling surface, more rigid and less apt to suffer road debris damage. The have NPT inlets/outlets which allow for AN fittings/ends and braided hose use.
Old Jan 16, 2007 | 06:24 PM
94legaleagle's Avatar
94legaleagle
Part number please??
Old Jan 16, 2007 | 06:31 PM
tiojames's Avatar
tiojames
I bought a B&M 24,000 from Summit. Low cost and it came with twice the amount of fittings, etc. needed to hook it up.
Old Jan 16, 2007 | 06:35 PM
Dealripper's Avatar
Dealripper
Default Trans Cooler
I use a Doug Rippie cooler on my Trans. It was installed by Tony's Corvette Shop in Gaithersburg MD.
Old Jan 16, 2007 | 06:53 PM
hotwheels57
That depends on the specific application and/or cooling requirements. They make them in a black powder coated finish or polished finish.
They have several listed on their website at bmracing.com...click on products and scroll for selection. SUMMIT RACING is probably the best source when you decide.
Old Jan 16, 2007 | 09:44 PM
naturalgas's Avatar
naturalgas
I Can't Find The Right Fittings For Lines And Don't Wan't To Cut Lines On Car I Have An O1 With The Large Metric Fittings I Think It's 18mm But Not Sure.
Old Jan 16, 2007 | 11:16 PM
4DRUSH's Avatar
4DRUSH
Cut the metal line and switch over to clamped rubber lines. Mine been that way for three years
Old Jan 17, 2007 | 03:55 AM
c5mtl's Avatar
c5mtl
Default bypass rad
is it wise to bypass the cooler in the rad and use the trans cooler as a stand alone??
Old Jan 17, 2007 | 08:40 AM
99 vett babycar's Avatar
99 vett babycar
Old Jan 17, 2007 | 09:31 AM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
use as a stand alone it will lower trans temps that way.
Old Jan 17, 2007 | 10:03 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Once the cooler is installed, can you just fill it up at the cooler vs. under the car? I Mean fill the cooler and the extra lines, or is it under pressure?
Old Jan 17, 2007 | 01:36 PM
4DRUSH's Avatar
4DRUSH
I installed mine after the rad.
You need to fill the trans up with fuild, take it for a ride and re-full
Very Very inportant trans is full
To Automatic Transmission oil cooler
