hvac lights not working at all
Old Jan 17, 2007 | 11:55 PM
trikflow77's Avatar
trikflow77
Default hvac lights not working at all
I bought a car on here a few weeks ago and the hvac lights do not work. The lcd screen works but all the other lights work. Is the power source bad or is there a fuse out?
Old Jan 18, 2007 | 12:10 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
You had a typo there, did you mean your screen works but no other lights work? Not even the orange LEDs? The screen going out is somewhat common but not all the button and dial lights.
I have mine tore apart right now to change the light colors so please clarify and I'll try and help.
Old Jan 18, 2007 | 01:33 AM
trikflow77's Avatar
trikflow77
DOh, i mean all the other lights DONT work. If i turn on the defrost the yellow light works, but all of the backlights do not work.
Old Jan 18, 2007 | 02:18 AM
tstar's Avatar
tstar
hmmm All those lights do share a common circuit. Let me do some digging around to see if I can find out what pin the light circuit is on the plug at the back of the unit. As far as I know there is no fuse solely for the lighting of the HVAC unit. You'll have to take the unit out to check the wiring and probably take it apart…
OR you can buy a used one.
OR get that one refurbished.
Old Jan 18, 2007 | 02:22 AM
tstar's Avatar
tstar
I'm assuming that you DO have the automatic climate control right?
FYI - You don’t have any of your car info in your public profile BTW, it’s a damn good idea to at least fill that in when you’re asking for help in here and also to list it when you’re describing the problem…
Old Jan 18, 2007 | 02:28 AM
trikflow77's Avatar
trikflow77
oh, ok, i will fill it out, i just bought the car and am obv new to the forum.
Yes i do have auto climate control and it is a 2000 frc.
Thanks for your help, i think i will take the sucker apart when i do the led mods on the rest of the car. Its just wierd because the yellow lights works (on the defrost) but none of the back lights work. Anyway, thanks for your help, i will see what i find when i take it apart.
Old Jan 18, 2007 | 02:45 AM
tstar's Avatar
tstar
Hey sorry if I came across like that, I meant it as friendly advice.
If you're planning on doing the LED mod check out the thread I'm knee deep in.... my pics are on page 6 on.... post 117 has a pic of my HVAC board lit up.
http://forums.corvetteforum.com/show....php?t=1588861
Old Jan 18, 2007 | 07:23 AM
99 vett babycar's Avatar
99 vett babycar
it was good friendly advice
Old Jan 18, 2007 | 10:57 AM
rws.1's Avatar
rws.1
they may just be VERY dim...
This is a VERY common problem do to loose(cracked) cold solder joints.
Lots of posts on how to solder your self...
You can also send out fo rrapir For under $50 to a CF member..
mandigital (David Ruberg) digitalguy_1@charter.net
You could e-mail him with specific syptoms to see if it is repairable...
Old Jan 18, 2007 | 11:04 AM
rws.1's Avatar
rws.1
this thread has everything you need to kow for the self fix and outside repair and buying a new one
http://forums.corvetteforum.com/show...limate+control
To hvac lights not working at all
