Rim and tire size
Old Jan 20, 2007 | 08:51 PM
RA91925's Avatar
RA91925
Default Rim and tire size
My front rims are 17" and 9.5" wide. Rear rims are 18" and 10.5" wide.
It looks like most of the P275/40ZR18 tires are rated for rims up to 11" wide, so I am good for the rear tires.
In tire size P245/45 ZR17, only the Goodyear F1 GS EMT is rated to fit on a rim 9.5" wide. I was looking at getting the Michelin Pilot Sport A/S ZP. Looks like they don't fit the front rims.
Is there another size that will fit the front rims and not create problems with body clearances?
Old Jan 21, 2007 | 12:36 AM
wamara's Avatar
wamara
Cruise-In II Veteran
I take it you want to stick with runflats?
Old Jan 21, 2007 | 08:50 AM
RA91925's Avatar
RA91925
Probably stick with run flats, but I have been thinking about getting the repair kit and compressor to carry. I have seen a lot of positive posts regarding benefits of non-runflats for noise and ride.
Old Jan 21, 2007 | 11:02 AM
hattitude's Avatar
hattitude
Those are the stock Z06 wheel sizes that come with 265/40-17 on the front and 295/35-18 on the rear. Alot of people bump up the fronts to 275/40-17 for GY GS-D3's and a couple others that don't offer 265's with no problem.
I believe these tires should fit your C5. As I understand it, the key is to make sure the overall diameter of the rear tire/wheel is taller than the overall diameter of the front tire/wheel to ensure the active handling works properly.
Old Jan 21, 2007 | 07:46 PM
RA91925's Avatar
RA91925
Default Tire sizes and active handling
Does anyone know if the relative rotation speed of the front and rear tires is a factor in the active handling system?
I'm looking at the following combinations and comparing them to the OEM tire sizes.
Goodyear 245/45-17 with 275/40-18 (OEM ratio 1.042254)
Michelin 255/45-17 with 275/40-18 (ratio 1.021879) My preference.
Michelin 255/40-17 with 285/35-18 (ratio 1.037594)
I'm assuming the slightly wider tire will have no real impact on handling or fit inside the wheel wells.
Old Jan 21, 2007 | 11:41 PM
wamara's Avatar
wamara
cartop,
I have seen people here on the forum use a lot of different tire size combinations; the combinations you mention should be of no concern to you at all. There seems to be a fair amount of "flexibility" in the algorithm used to activate the AH - you certainly don't need to precisely stay with the factory's front/rear circumference ratio. Conventional wisdom says just don't let the front tire circumference get bigger than the rear.
The wider tires will fit fine; you can easily run Z06 widths and beyond (obviously up to a point ) on your car w/o problem.
Old Jan 22, 2007 | 07:17 PM
RA91925's Avatar
RA91925
Default Thanks for the help everyone.
After considering the responses, I will probably go with the
Michelin 255/45-17 with 275/40-18 (ratio 1.0219)
or possibly
Michelin 255/40-17 with 275/40-18 (ratio 1.0656)
Thanks for the help.
To Rim and tire size
