Best place to......
Old Jan 21, 2007 | 10:09 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Default Best place to......
Guys I am looking for an ARP bolt for oem crank pulley. Where is the best place to get it? I have heard its longer than stock bolt. Will it work with stock pulley and does it require TTY or just torqued to a certain spec?
Also, where in the heck will I find something like this degree wheel???
I think I can use this degree wheel and use it with my 150lb torque wrench to torque my pulley to the specs with stock bolt instead of buying a 250lb torque wrench
Thanks for all the help in advance
Old Jan 21, 2007 | 11:32 PM
FactoryRaceCar
Old Jan 21, 2007 | 11:36 PM
zeevette's Avatar
zeevette
Texas Speed should have the ARP bolt. I've never seen a wheel like that one. Is it to give you degrees of rotation for TTY? If so, want the GM bolt, I think?
Old Jan 21, 2007 | 11:42 PM
FactoryRaceCar
Yeah Dave I am thinking just get an ARP bolt and torque it to 200lbs and get done with it. What is required for the ARP bolt torque wise?
To Best place to......
