Auto Trans., Any Good??
Old Jan 22, 2007 | 08:22 AM
Nick1's Avatar
Nick1
Default Auto Trans., Any Good??
Is the recent C5 auto much better than the prior generation 4L60E??
I'm concerned that pushing it around a little will result in the loss of downshift ability which happened in my '96 Camaro.
Old Jan 22, 2007 | 09:18 AM
David426's Avatar
David426
4l60e= piece of S*** . Replaced mine at 38,000 miles under warranty.. Heat kills these things quick. And they do heat up quickly in the Summer..
Old Jan 22, 2007 | 11:15 AM
firstvette99's Avatar
firstvette99
what is the stock auto trany?
Old Jan 22, 2007 | 11:50 AM
Vetteoholic's Avatar
Vetteoholic
Yes, from what I've read the C5 Is a better tranny. If I went with an auto I would go with a 01+ with the 3.15 gears because the torque comes on at 4000 vs 4400 It has 5 hp and 10lb ft more too. Not much on paper but the 01+ auto seems to run a couple of 10ths faster In the quarter than the pre 01's with the same gears.
I love the manual though....If I did choose the auto I would want the most power since Its the auto and not a manual...thats just me
Old Jan 22, 2007 | 06:59 PM
arkansascorvette's Avatar
arkansascorvette
Default A4 automatic trans
I also heard from "those" in the know that the A4 (4L60E) wasn't a very strong tranny. Having said that, my 2002 thats Magnuson equiped has been getting flogged now for 3 years and 21K miles with no signs of wear or tear. Trans fluid is synthetic and cooled with a large cooler. Fluids been changed twice now, at 9K and just recently with a clean pan, no particals or debris in the pan and fluid smells close to fresh fluid. I run 11 X 19 rears with the new second gen 06 runflats.
What kills a 4l60E faster than anything is high stall convertors and heat,
plus large sticky tires. Got to know your limitations; of course a genius tuner can make the A4 live a long time.
Old Jan 22, 2007 | 08:44 PM
Vetteoholic
Your Corvette Is awesome looking!! Wow, I really like the Caravaggio Spoiler & Side Splitters! Even the Hood seems to fit nicely. Ofcourse I also love the C6Z Wheels too Amazing
Old Jan 22, 2007 | 10:44 PM
Moval49er's Avatar
Moval49er
Totally agree! Long live SW!!
Fine looking ride.
Old Jan 22, 2007 | 10:59 PM
arkansascorvette
Thanks for the kind words, guys; the car is a work in progress.
Old Jan 23, 2007 | 12:07 AM
nmbis2k's Avatar
nmbis2k
I had a B&M flat plate trans cooler installed, in series. Dropped the average temp by 30-40 degrees. That will help any automagic live longer.
Old Jan 23, 2007 | 11:09 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If you have some hot weather and are concerned about heat, then get the cooler. Very easy to install and costs under 50 bucks.
To Auto Trans., Any Good??
