ABS Problems with this tire combo
Old Jan 23, 2007 | 10:15 AM
kromberg's Avatar
kromberg
Default ABS Problems with this tire combo
Stock:
245/45/17 : 25.68"
275/40/18 : 26.66"
New:
275/35/18 : 25.57"
335/30/18 : 25.91"
Keith
Old Jan 23, 2007 | 10:25 AM
6Speeder's Avatar
6Speeder
You should be fine. On my Y2K the front and rears are the same diameter, no issues with TC or ABS
Old Jan 23, 2007 | 01:24 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I have run w/o issue:
F 275/35/18 & 345/35/18 or 345/30/18
F 275/35/18 & 295/35/18
F CCW 16" skinny and 345/30/18 on back
I have even run 275/40/18 on all 4 with no issues.......
Only time I ever had one ( I knew I would) 275/35/18 front and 275/40/17 rear just at the drag strip though...........
Old Jan 23, 2007 | 01:41 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
are you going to tub the rear for the 335???
I dont see a problem with that combination.
I run 295F 315R 18 for the street and 295F 315R 17 for the track both with no problems...
Old Jan 23, 2007 | 01:43 PM
Wicked Weasel
there are guys running 315 all around on the track. ABS is still good, but I think TC is not.
As a matter of fact my TC doesn't like the type of tire I am running on the track either
Old Jan 23, 2007 | 02:05 PM
kromberg's Avatar
kromberg
Yes. I am setting a set of 18x10.5 thin spokes widened to 12" like ALLTHROTTLE&NOBOTTLE did. Hopefully the wheels will be done in a week or so, then I will start the tubbing project
Keith
Old Jan 23, 2007 | 02:07 PM
kromberg's Avatar
kromberg
The other question is, should I go ahead a set the tire size in the PCM to 25.91" or just leave it with the stock height?
Keith
Old Jan 23, 2007 | 02:13 PM
Cruise-In V Veteran
NCM Ambassador
Hehehe...........275/35/18 Hoosiers on all 4 on the 00' coupe and it likes them with TC on or off.
Had to take it our for a spin to "heat cycle" them.........These will be at VIR on one of the cars
Old Jan 23, 2007 | 02:16 PM
Wicked Weasel
Hehehe...........275/35/18 Hoosiers on all 4 on the 00' coupe and it likes them with TC on or off. Had to take it our for a spin to "heat cycle" them.........These will be at VIR on one of the cars
I am running 17in V710s and at Limerock and WGI I have TC problems. I run without TC anyway so it is not a big deal, but if I forget to take it off I feel it working against me.
AH is always on
Old Jan 23, 2007 | 02:17 PM
Cruise-In V Veteran
NCM Ambassador
Keith
Look kinda normal from here
Now that the 97' is back on the ground, its time to fit these up and get some meat on them
Old Jan 23, 2007 | 02:23 PM
kromberg's Avatar
kromberg
I found a pretty good source for meats. I picked up a set of 275/35/18 and 335/30/18 with about 80% thead for $400 shipped
Keith
To ABS Problems with this tire combo
