Squeel/Whine from Rear when Cornering?
Any ideas on what would cause this? I've been hearing squeeking from my rear suspension going over speedbumps, and sometimes a single 'click' from the back when i apply the brakes for the first time in the AM., any of these related? No codes in the DTC, and the car seems to handle fine... (even when suspension is broken this car handles well... lol)
Initially i thought maybe my brake squeeler was rubbing when i corner for some reason... i can't think of anything else. Any help would be great!
EDIT: On 2nd thought, does my ebrake have a squeeler or anything, any reason why cornering would cause it to squeel?
Dan
The squeel only happens when the clutch is engaged, and there is a slight load (or more) on the throttle... the squeel will quiet down as the throttle decreases (to a point where you can't hear it) and dissapear w/o thottle or load...
So, if it were something like a squeeler or suspension component it would squeel in the corner regardless of drivetrain's engagement... so it has to be something realted to the drive train right? From Tire to Engine...
So we're looking at what? CV-Joint? Wheel bearings? Differential Output shaft? What else?
Thanks,
Dan
How do i check for problems such as:
bad wheel bearing
bad tranny mount
bad cv-boot/joint or damage from poor lubrication
I think i know how do to all that, but i'm looking for as many second opinions as possible, any tips or information is helpful...
Dan
