Cam package install special...
Old Jan 23, 2007 | 05:59 PM
DinoZ's Avatar
0DinoZ
Supporting Tuner
Default Cam package install special...
For the next month, we're going to run this special, for parts, labor, and tune, for a cam under a .600 lift. It includes all of the parts, including gaskets, fluids, high volume oil pump, etc.
$2665 plus tax, out the door.
PM me for details, if interested... or you can call the shop and talk to myself, or JP.
Old Jan 24, 2007 | 11:31 AM
TLewis4095's Avatar
TLewis4095
Old Jan 25, 2007 | 11:02 AM
TLewis4095's Avatar
TLewis4095
TTT, This is a great price if you are considering the step-up!
Old Jan 27, 2007 | 12:58 PM
TLewis4095's Avatar
TLewis4095
TTT
Old Jan 27, 2007 | 10:09 PM
STOCKER's Avatar
STOCKER
how many hours labor??
Old Jan 28, 2007 | 12:43 AM
molten vett's Avatar
molten vett
how much hp should i expect from an otherwise stock engine and what kind of idle quality?
Old Jan 28, 2007 | 12:53 AM
lytspeed1's Avatar
lytspeed1
Default cam install
How long do you guys need the car...I ll be down in Brooksville in Feb I think......03 C5 A4,headers and long tubes
Old Jan 29, 2007 | 02:17 PM
DinoZ's Avatar
0DinoZ
Supporting Tuner
All depends on the cam, and what else is done to the car. But on M6 cars with nice exhausts, and an underdrive pulley, we've seen as much as 405rwhp, out of our 224/228 cam. That cam is usually anywhere from 390-405, depending on the car. Out of the dozens that we've installed, most of them are right around the 400rwhp mark.
Idle quality would be very good. Enough of a lope to tell that there's a cam in it, but nothing too radical. This has been a favorite cam for those who want a significant power increase, but keep stock-like drivability.
Old Jan 29, 2007 | 02:21 PM
DinoZ's Avatar
0DinoZ
Supporting Tuner
If we could have the car for 3 days, that would be good. There's a heat cycle period that has to be done, due to the springs, and that takes a solid half day, or more, just to do that.
Old Jan 29, 2007 | 02:22 PM
DinoZ's Avatar
0DinoZ
Supporting Tuner
Do you want to know how many hours of labor are being charged, or are you wanting to know how long it will take?
Old Jan 29, 2007 | 03:33 PM
kromberg's Avatar
kromberg
One can do the math:
cam: $395ish
oil pump: $150ish
pushrods: $100ish
springs,locks,etc: $350ish
timing chain: $150ish
gaskets and bolts: $100ish
fluids: $50ish
tune: $500ish
$1800ish in parts and tune
$865 difference. Most shops charge $100/hour labor. 8.5 hours for installing a cam?
Keith
Old Jan 29, 2007 | 03:51 PM
DinoZ's Avatar
0DinoZ
Supporting Tuner
Cam - $395
Springs - $175
Seals - $15
Seats - $35
Tit. Rets - $270
Hardened Pushrods - $125
Wtr pump gaskets - $7
Frnt cover gaskets - $20
Melling LS6 h/v oil pump - $150
Timing set - $185
Crank Bolt - $9
Frnt seal - $19
Mobil 1 oil - $40
Oil filter - $6
Coolant - $23
A/C evac and recharge - $90
Labor - $675
Dyno tune - $400
Shop supplies/disposal fees - $25
Old Jan 30, 2007 | 01:32 PM
TLewis4095's Avatar
TLewis4095
TTT
Old Jan 31, 2007 | 06:49 PM
TLewis4095's Avatar
TLewis4095
Has to be more interested in this.....
Old Feb 1, 2007 | 12:58 AM
Cali's Avatar
Cali
yeah, i'm interested but not in FL.. (sigh)
Old Feb 1, 2007 | 11:12 AM
STLKillerC5's Avatar
STLKillerC5
I would recommend that if you're getting this work done you might as well add some new heads!!!
Old Feb 1, 2007 | 03:54 PM
TLewis4095's Avatar
TLewis4095
To Cam package install special...
Old Feb 3, 2007 | 11:50 AM
DinoZ's Avatar
0DinoZ
Supporting Tuner
We've got our first taker on this deal coming in on Wednesday!
Old Feb 5, 2007 | 10:16 AM
TLewis4095's Avatar
TLewis4095
We have slots open to get first takers in right away!
Old Feb 5, 2007 | 10:20 AM
SteveGel's Avatar
SteveGel
how hp gain from a 01 z06 has cai, headers,x-pipe?
