Pothole meets HRE wheel - help
Old Jan 24, 2007 | 01:01 AM
STLBLUES's Avatar
STLBLUES
St. Jude Donor '09
Default Pothole meets HRE wheel - help
My friend hit a pothole and bent one of his HRE wheels. We called HRE and they want around 500 for the repair. That was for a new rim bolted to his center. How much would a wheel shop charge to repair/ straighten the bent rim? Does anyone know of a good shop near Oklahoma?
Thanks, Steve
Old Jan 24, 2007 | 09:37 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
how bad is it? pic's
Old Jan 24, 2007 | 11:04 AM
RskyBns's Avatar
RskyBns
HRE is a pain in butt. They have great looking wheels. I have 19" & 20" 547's on for the last couple years. One started leaking through a hairline crack in the outer....took 2 months to get it all back and pretty much could care less about anything except charging an arm and a leg for the repairs. And I only live right up the road from them! Now I have another wheel that is starting to do the same thing. Crazy thing is they have just gone through normal driving....no off-road or racing or even hitting potholes.
So good luck to you in whatever happens. Beautiful wheels, unfortunately, not worth the headache for me when this kind of stuff happens.
Old Jan 24, 2007 | 11:53 AM
STLBLUES's Avatar
STLBLUES
St. Jude Donor '09
I will try to get a pic to share. Its bent bad. I dont think a rubber mallet will fix it. It might but its hard to beat on a high dollar wheel
Ducati749's Avatar
Ducati749
Around the bay area...I hear of people getting bent rims fixed for 300. However i believe this is for a bare aluminum rim, are they finished?...500 seems steep to me but i bet the rims will be in tip top shape...It appears these rims crack as well...If it were me i would sell off the rims and pick up diff ones.
Old Jan 24, 2007 | 12:03 PM
Ducati749's Avatar
Ducati749
Some info:
-The wheel shops use a lead mallet to bang back the rim.
-Aluminum doesn't bend back well, especially forged. (if the bend angle is too steep when you bend it back it will crack)
-Heat will help aluminum not crack when bending (But if you rims are forged, heat can dampen the forged effect, not to mention the finish.
Old Jan 24, 2007 | 01:12 PM
Blue Lightening's Avatar
Blue Lightening
I think I might almost qualify as an expert on this matter. I went thru three bent front HRE rims prior to solving the problem. Each time it was the outer rim on a front tire. It does not take much of a pot hole or road defect to bend the outer rim on an HRE.
I looked into getting the bends repaired but they have to heat them and no company would gaurentee the results. The best thing to do is to replace the outer rim. I have never had any problems with leaking after repair and neither should you if they were put together properly.
The third bent rim ticked me off the most. I was going less than 15 mph in a driveway on a cell phone not paying attention and hit a small pot hole. It is amazing that the rims bend but the tire doesn't go flat.
The solution was to install wider tires on the HRE. I was running Pilot Sports 255x35x18 on the front. The side walls were not sticking out far enough to protect the rim. I switched to a wider tire 265x35x18's and have had zero issues with them ever since.
Old Jan 24, 2007 | 06:52 PM
Face's Avatar
Face
I'll stick to my CCW's, thanks.
To Pothole meets HRE wheel - help
