C6 Z51 Brake Upgrade
Old Jan 24, 2007 | 01:28 AM
hightest's Avatar
hightest
Default C6 Z51 Brake Upgrade
I would like to upgrade my C5 brakes to the new Z51's, and was wondering if anyone knows if the caliper braket required for the bigger rotors can be ordered through GM? Would it be the same caliper bracket that comes stock on the C6's.
Thanks!
Old Jan 24, 2007 | 01:38 AM
Dr. Pham's Avatar
Dr. Pham
Yup...been there done that
To run C6 Z51 rotors (13.4" FRT and 13" Rear) on a C5 and reusing the C5 calipers...you need the C6 Z51 brackets which will move the calipers further out to accomodate for the larger diameter rotor. Also be aware that you'll also need to be running 18" wheels up front.
Here are the bracket part numbers 88964166 and 88964167.
Cheers
Old Jan 24, 2007 | 01:39 AM
hightest's Avatar
hightest
Thanks Doc, appreciate the help !!
Old Jan 24, 2007 | 01:45 AM
hightest's Avatar
hightest
One more question.
Are those part numbers for left and right, or for front and rear?
Thanks again!
Old Jan 24, 2007 | 08:45 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
www.gmpartshouse.com
Old Jan 24, 2007 | 08:58 AM
VetteDrmr's Avatar
VetteDrmr
I'm assuming you're doing this for the bling? FYI, C6 Z51 rotors are the same, both left and right sides. With the directional vanes, one side is pulling air from the hub area out, and the other side is pulling air from the rotor edge inward (backwards).
Won't make any difference on the street, but if you autox or track the car...
Have a good one,
Mike
Old Jan 24, 2007 | 09:30 AM
robvuk's Avatar
robvuk
Have a good one,
Mike
The larger diameter rotors do offer a little more than bling. The reverse rotor still draws air in from the center to the low pressure/high velocity outer edge. Only the efficiency is ever so slightly affected.
Old Jan 24, 2007 | 11:01 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Cheers
hey doc, don't you need 4 part numbers?
Old Jan 24, 2007 | 11:32 AM
SteveDoten's Avatar
SteveDoten
flip them over for L and R, IIRC
Old Jan 24, 2007 | 06:25 PM
robvuk's Avatar
robvuk
Exactly. Believe it or not, this saves GM hundreds of thousands of dollars during the lifetime of each part number.
Old Jan 24, 2007 | 08:56 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Hi All,
Thanks for the plug! You can order them online at my site at any time...
Use the following part numbers under Chevrolet make for the whole kit...
88964166 front caliper brackets
88964167 rear caliper brackets
89060328 front rotors
89060329 rear rotors
Thanks,
Gene
Old Jan 24, 2007 | 09:18 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by Gene Culley
Hi All,
Thanks,
Gene
thanks for the info, gene.
can you provide me with part numbers for front and rear C5 Z06 pads and/or any other items to be replaced with a brake job? (e.g. anti-rattle shims or whatnot)
-edit. nm, i already ordered from ya.
Old Jan 24, 2007 | 10:19 PM
VetteDrmr's Avatar
VetteDrmr
I'm not going to get drawn into that debate again; as I said in the beginning, they're fine for the street.
Have a good one,
Mike
Old Jan 24, 2007 | 11:15 PM
robvuk's Avatar
robvuk
Have a good one,
Mike
Wasn't a debate. just a fact.
Old Jan 25, 2007 | 12:54 AM
Bill Dearborn's Avatar
Bill Dearborn
Too much has been made about the reversing of the rotors but when you do a little analysis you see it really doesn't make much difference. If we could set up a test rig and measure rotor temps with air flowing as it does in a car wheel well the difference would be negilible.
Bill
Old Jan 25, 2007 | 02:02 AM
Dr. Pham's Avatar
Dr. Pham
Whoops...been away and just noticed the questions...As others have already stated...
The part numbers I gave were just for the brackets...front and rear. So you would need two of each set.
The main reason I went with this setup was to fill in the space between the rotor and the wheel when Iwent up to 18"s in the front. The rear's I felt were always a little too small looking as well. Not a big fan of large diameter rims and smallish looking rotors. This setup fixed that up real quick, was easy to do, looks good, and not too expensive.
Best of luck on the mod!
Old Jan 25, 2007 | 09:48 AM
robvuk's Avatar
robvuk
Bill
People think the vanes in the rotors work like fan blades. The air still goes in at the bottom and out at the top.
Old Jan 25, 2007 | 11:02 AM
426 Hemi's Avatar
426 Hemi
Sounds like we need to submit this to MythBusters.
To C6 Z51 Brake Upgrade
