wheel & tires sizes
Old Jan 24, 2007 | 04:20 AM
socalsavage's Avatar
socalsavage
Default wheel & tires sizes
My 99 coupe is lowered on stock bolts and I was wondering if I could run a 18" and 19" wheel set up. If so what width on the wheels and what size tires. dont want any rubbing issues.
Thank You
Old Jan 25, 2007 | 07:44 AM
socalsavage
"ttt"
Old Jan 25, 2007 | 11:37 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Yes, you can run an 18/19 setup. Typical wheel widths will be 9.5-10" front, and 10.5-11.5" rear. However, I'd suggest that you approach this from the opposite direction, and decide what tires you want to run, then get wheels to fit. Typical tire sizes will be 295/30 or 305/30, fronts 275/35 or 285/35. Don't forget you can also use the runflats that come on the C6.
These are just some guidelines; I'm sure they're not all-inclusive.
Old Jan 25, 2007 | 10:06 PM
chuck1026's Avatar
chuck1026
I am getting 18x9.5 front and 19x11 rear wheels with 245/40/18 and 285/35/19 Goodyear F1 Supercar EMT's (C6 Z51 tires). I picked out the tire sizes and matched the rims to them (with the guidance of John at CCW.
You can fit the 275/305 setup in non-runflats.
Old Jan 26, 2007 | 12:03 AM
Russ K's Avatar
Russ K
Keep in mind that the sidewall of a 275/35/18 is taller than a 305/30/19. A 263/35/18 would be a better choice.
Russ Kemp
Old Jan 26, 2007 | 03:14 AM
socalsavage
Default wheels sizes
Thanks for the input gentlemen. Always a ton of help.
virgil
Old Jan 26, 2007 | 11:54 AM
wamara's Avatar
wamara
Russ Kemp
Russ, the specific sidewall profile betweeen front and rear tires is irrelevant, although it obviously impacts the tire measurements which are at issue. The general concern is that the circumference (aka rolling diameter) of the rear tire be greater than that of the front tire, so as to avoid AH problems. A 275/35-18 tire has approx. an 80.4" circumference; the 305/30-19 has approx. an 82.3" circumference.
Old Jan 27, 2007 | 08:59 AM
Iron Chef's Avatar
Iron Chef
St. Jude Donor '06-'07-'08-'09
CI 8-9-10 Veteran
This is the post I was looking for as I want to do the same thing. But here's my n00b question: With these tire sizes, will the tires not stick out past the fenders? I've seen that on a few cars and I'm not crazy about the look. Thanks!
Old Jan 27, 2007 | 10:38 AM
wamara's Avatar
wamara
Iron Chef,
Whether a tire protrudes past the fender lip depends not only on the width of the wheel/tire combination, but also the offset of the wheel. So its impossible to say unless one knows the specifics, or alternatively you see what other people are running and how their setup looks to you. I can tell you that with my Z06 setup (OEM wheels and OEM tire sizes) on my coupe, the rears do not stick out past the top of the fender lip, and the fronts stick out maybe an 1/8" or so.
I've heard it said (w/o any verification) that the various production tolerances on these cars are such that one will find some variation of this wheel/fender relationship from car to car.
Old Jan 27, 2007 | 11:02 AM
chuck1026's Avatar
chuck1026
Iron Chef,
Can you show us pictures of this setup? What width rims and offsets are you using? I was under the impression that 325/30/19's would stick out approx 1/4" at the very least... when stuffed on an 11" wide wheel. That is SWEET if they tuck on yours!
Old Jan 27, 2007 | 11:45 AM
wamara's Avatar
wamara
chuck1026,
I don't have any pics at the moment, but in any event perhaps I wasn't clear as to my setup, which is not unique by any means. I have the OEM C5 Z06 wheels on my '01 coupe. The wheels are 17x9.5" fr and 18x10.5" rr, with Toyo Proxies T1-S tires, 265/40-17 and 295/35-18 respectively. I'm sure the offset specs are published here somewhere.
Old Jan 27, 2007 | 12:43 PM
chuck1026's Avatar
chuck1026
chuck1026,
Oops... I thought you wedged on C6 Z06 tires! :o
Old Jan 30, 2007 | 05:27 PM
Russ K's Avatar
Russ K
The higher side wall on a 275/38/18 compared to the side wall height of a 305/30/19 looks odd. That's why I'm using 265/35/18 front tires.
Old Jan 30, 2007 | 05:33 PM
Russ K's Avatar
Russ K
Use 18x9.5 rims with a 54-59 mm offset (265/35/18) and 19x11 with a 62-65 mm offset (305/30/19) The tires will not stick out with this combo.
Russ Kemp
Old Jan 30, 2007 | 08:20 PM
wamara's Avatar
wamara
I'm not looking to start an argument, but the difference in sidewall height between a 265/35-18 and a 275/35-18 (I assume you mean this size as I'm pretty sure a 275/38 does not exist) is just a bit more than one tenth of an inch, but anyway as long as you like what you've got and are enjoying your car, that's what is important
To wheel & tires sizes
