External Temp stuck at 69*F
Part #10248414
Cost -$5.42
Replacement is simple Front Passenger Side on rail between headlight and radiator...
Found this in another thread " Disconnect the sensor. You should get DTC B0333 Outside Air Temp Sensor Open, and the temp display should default to 56*F. This would tell you that there are no shorts in the wiring harness/connector.
Short the sensor connector - this won't blow anything. You should get DTC B0332 Outside Air Temp Sensor Short to Ground, and the temp display should default to 56*F. This will confirm that there are no random impedances in the circuit.
Measure the impedance of the sensor itself. At 68*F, it should measure 12,493 ohms. At 86*F/8,056 ohms, 104*F/5327 ohms. That should be enough to verify it's within its expected range.
If you're still having a problem, then the only other possibility is the HVAC unit has a problem internally where the sensor impedance is used in conjunction with it's reference circuit. The reference circuit consists of a 5V voltage and a reference resistor. I can't see how it could be this though.
Also remember that the display will not update if the car was started less than 3 hours ago. You need to drive it above 20 MPH of 90 seconds or above 45 MPH for 60 seconds. "
Or:
Maybe KITT has reincarnated himself into your car and is trying to tell you something......
Point being - dont let it go - get it fixed or you will be wishing you did if you get in a foggy situation (on the windshield that is)
