My Error Codes
Old Jan 24, 2007 | 05:15 PM
MNCorvette's Avatar
MNCorvette
Default My Error Codes
I am guessing the first two are from my fuel gauge going to zero every now and then. I've used Techron fuel system cleaner numerous times so I am planning on living with this until it goes out for good. Let me know if my guess is wrong.
P0461 Fuel Level Sensor 1 Circuit Performance
P1431 Fuel Level Sensor 2 Circuit Performance
Anyone have any idea what this next code means?
P1518 PCM to TAC Module Serial Data Circuit
And finally the last two. Discount tire wasn't able to install tire preasure sensors in two of my tires which generated these codes This is also something i've learned to live with since I have a 98 a4 and i know it can't be reprogramed to stop looking for tpm's
C2110 Right Rear TPM Sensor Malfunction
C2115 Left Rear TPM Sensor Malfunction
Any help with any of these codes would be great especially P1518 PCM to TAC Module Serial Data Circuit
Old Jan 24, 2007 | 05:58 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Probably more than you want to know, but here are the service procedures for 1998 Powertrain codes.
If the Techron is not helping, try this:
Mix 1 gallon of Toluene or Xylene with 1oz of ATF or Marvel Mystery Oil, and add to a half tank of premium gasoline. At this ratio, it is harmless to your seals and fuel lines, but will have a cleansing effect on your fuel sender. It will also slightly boost octane. These are both available from paint supply stores (I buy them at the local Sherwin Williams).
GL!
Old Jan 27, 2007 | 08:18 PM
MNCorvette's Avatar
MNCorvette
Default thanks
thanks mr lucky i'll give it a try when i start her up again this summer.
To My Error Codes
