Window motor TSB??
Old Oct 3, 2001 | 03:29 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Window motor TSB??
Does anybody have a copy of the window motor TSB? If such a thing exists.
Both of mine started growling when going up and down about 4 months ago, two weeks ago one of the motors went out and I got it replaced yesterday. I'm worried about the other side doing it too.
The new motor does not make the growling noise.
Eric
Old Oct 3, 2001 | 06:23 PM
Jim Davis/Nasty1's Avatar
Jim Davis/Nasty1
Default Re: Window motor TSB?? (66ImpalaLT1)
Yep! :yesnod:
Our window motor went out on the pass side without any warning at all. :rolleyes: From talking to club members it has happenened to a lot of them. It just happened to my Silverado too. Must be the same motor.
Jim :seeya
Old Oct 3, 2001 | 08:45 PM
Nekbyter's Avatar
Nekbyter
Default Re: Window motor TSB?? (Jim Davis/Nasty1)
My 2K FRC had the pass. side window motor die w/o warning too. It happened just 2 weeks ago.
Old Oct 3, 2001 | 08:48 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Eric
Bulliten #00-08-64-004...L/S #10446574 R/S #10446575...The growl noise comes from the window regulator cables not the motor...The regulator comes complete with a new motor as an assembly...
Old Oct 3, 2001 | 10:02 PM
66ImpalaLT1
Default Re: Window motor TSB?? (C-5 TECH)
Thanks. I dont know if it was the motor that went out, but they told me they replaced the motor and regulator.
Should I get them to fix the other side also, even though it still works?
Eric
Old Oct 3, 2001 | 10:55 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Eric
Look at it this way...I replace 10 right sides to every left side...The motors simply get a dead spot from lack of use.If the regulator cables are growling,I would replace it.
To Window motor TSB??
