Pilot Bearing Question
Old Jan 25, 2007 | 12:57 AM
2004SpiralGrey's Avatar
2004SpiralGrey
Default Pilot Bearing Question
I am building a 383 with an Eagle Forged Crank. I went to tap in my NEW GM factory pilot bearing and it just slides in easily when i turn it in there the bearing turns on the inside of the crank ...it isn't a tight fit? Whats the problem?
Old Jan 25, 2007 | 01:03 AM
FRCTony's Avatar
FRCTony
Wrong bearing? Sorry had to say it.
Seriously, I would be on the phone to Eagle real quick.
Old Jan 25, 2007 | 01:12 AM
2004SpiralGrey
does anyone have a part number for the correct part ???
Old Jan 25, 2007 | 02:03 AM
CrazyChris's Avatar
CrazyChris
Call Eagle. There was an issue with some of their cranks and they sell the bearing that fits.
Old Jan 25, 2007 | 02:18 AM
2004SpiralGrey
thanks chris i will be doing this in the morning...i'll keep everyone posted
Old Jan 26, 2007 | 10:03 AM
2004SpiralGrey
So I called Eagle yesterday and they said the only way to fix the problem was to put a knurled pilot bearing in...SoOoOoOo they are going to ship me one out FREE of charge...Great customer service !
Old Jan 27, 2007 | 03:03 PM
CrazyChris's Avatar
CrazyChris
Good to hear.
Old Jan 27, 2007 | 07:12 PM
leo12's Avatar
leo12
i am having the same problem ..does anuone have a phone number on eagle?
Old Jan 28, 2007 | 02:47 AM
2004SpiralGrey
662-796-7373
Old Jan 28, 2007 | 07:56 AM
leo12's Avatar
leo12
thanks much grey
Old Jan 28, 2007 | 10:29 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I wouldn't be to happy with that solution as the next time you need a pilot bearing where are you going to get one from.
Knurling the pilot bearing, means that they pull on the outside of the metal case to close the gap tolerance (i.e. your crank was out of spec and should have been trashed).
I would expect a new crank from them at the very least.
Old Jan 28, 2007 | 11:25 AM
nuke61's Avatar
nuke61
^^^ I agree... it sounds like they screwed up, ended up with cranks with I.D.s that are too big. The cheap solution is to take stock bearings and knurl it. The RIGHT solution is to recall the cranks and send out ones that have the correct crank I.D. so a STOCK bearing fits correctly.
Old Apr 16, 2007 | 06:16 PM
AlwaysInBoost's Avatar
AlwaysInBoost
how did everything work out??
To Pilot Bearing Question
