Stupid questions! 402?
. Assuming I want the LS2 at some point in the future would it make sense to save up for that and get bolt on stuff like headders/Xpipe, heads, cam, etc before doing the swap?... Will any of that fit on a LS2 short block? I want everything to work well in the end and still be a good upgrade for when I have the money to do it. I did all the bolt on installs on my VR4 but doing a swap is an all new area for me so just thought I would ask here where the info is.
YOu can get LS2 stroker 402 motors now build for around $7,000.00 and in the meantime just focus on finding yourself the right vette that you want as that will be the biggest part to complete and then build the motor and get the right headers, intake for the 402 LS2 motor when you can afford all of it.
If you buy performance engine parts for your stock 346 cube LS1/6 motor in the C5 your buying, your just wasting $ if its the 402 LS2 stroker you want, as you will have to redo the heads and cam to make optimal power with the LS2 motor. The heads and cam and everything else would be interchangeable between the two motors but just would not be the right choice of parts on the bigger stroker that has 62 more cubic inches (346cid in a stock LS1/6 vs 402 cubes in a LS2 stroker motor with 4.00 inch eagle crank).
If you want to get a big seat in the pants performance gain in the new C5 simply add 4.10 gears and you will be
for sure and save up for that perfectly speced/built LS2 402 stroker (which by the way is an awesome motor that will make an easy 500 rwhp)
Honestly, consider putting in 4.10 gears as the car will wake right up and 6th gear will become useable and with the stroker motor in the future you will really be hauling azz!!
. Assuming I want the LS2 at some point in the future would it make sense to save up for that and get bolt on stuff like headders/Xpipe, heads, cam, etc before doing the swap?... Will any of that fit on a LS2 short block? I want everything to work well in the end and still be a good upgrade for when I have the money to do it. I did all the bolt on installs on my VR4 but doing a swap is an all new area for me so just thought I would ask here where the info is.If you are planning on heads and cam, then you don't even have to buy the Z06, just do the same to your LS1. With 6 bolt mains, the LS1 is good for 700 hp on the stock bottom end. Lots cheaper. Leaves you money to buy those 4.10s with.
Hammer
Is there anywhere where I can read all about stroking an LS2? Its never been an option with any car I have owned up till now so I know nothing about it.
Edit: looked on autotrader, cant find any hard tops for less than 19k within 300 miles of me, is there anywhere else I should look for one?
if you are serious about finding a cheap frc, you will need to fly/drive; there is one in C5's 4sale for 15 or 16, it's white in NJ, slashed seats, some paint blems
I have been reading this forum for quite some time. I believe you should take the advice of Steve in CT ...find a used C5 that you would enjoy.
If your not tracking it and want wind in the hair then get a convertible.
If you think you might enjoy going to track events then decide if you want the hatchback with the lift off roof or a 1999/2000 FRC (fixed roof coupe)
Buy the car you like. Then in my opinion contact Steve in conn. as he has a great reputation and great pricing.
You tell him what you want to achieve and steve can lay out the options and the costs.
If it were me? I'd go with the l92 414 cubic inch motor and the worked heads (dual valve springs) and l76 intake.
Steve has one of the finest computer tuners from what has been discussed on these forums. (slowhawk)
I think you'd be best served in finding the car you want. Enjoying it and dropping in the motor and clutch at the same time. I've heard the textrella clutch is good but have no first hand experience with it. I think its better than the ls7 clutch package.
As far as small bolt ons? Don't waste your money. Do an air filter mod and then step up to the motor/header/clutch and I wouldn't bother with the rear gears...
Of course if you find a higher mileage corvette of your dreams for 15 grand or so....and drop the motor in right away...
That would be the best of both worlds...
Best of luck and enjoy.
The C5 is a hell of a car.
Hammer
Compare this to an LS2 (402) short block for ~$4500 or an LS7 short block for ~$6000.
I'm just throwing some options out there. The original post said that he wanted to change his (future) LS1 to an LS2. That is a lot of money to spend for an increase of only 18 cu/in.
.The C5 Z06 with just basic bolt-ons (headers/intake/gears) is a very strong combo.
I suggest that you find a corvette club in your area and seek out rides in a Z06 and C5, both stock and lightly moded, that will give you a good base line of what to expect. JMHO.
