Windshield Question
Old Jan 28, 2007 | 10:16 AM
HT1663WB's Avatar
HT1663WB
Default Windshield Question
Curios, I have heads up display can I just use a standard windshield?
Old Jan 28, 2007 | 10:35 AM
drbvac's Avatar
drbvac
According to the sales brochure there is something different about the glass but i could be wrong
Old Jan 28, 2007 | 10:44 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
I believe the HUD windshield has a higher reflective quality for the inside. Hence the high replacement cost. But I understand a standard windshield will work with a HUD also.
Old Jan 28, 2007 | 10:45 AM
Mike Mercury's Avatar
Mike Mercury
yes, you can use the standard windshield.
But there is a difference between the two. The "HUD" windshield has an "anti-parallax" layer between the two glass layers that helps reduce a slight ghosting outline of the image. This "anti-parallax" layer has little to do with illumination... and everything to do with making a more crisp display of the projection.
Old Jan 28, 2007 | 11:48 AM
RED99's Avatar
RED99
I installed a HUD and I have ghosting (BIG TIME) on the standard windshield. I am only assuming it's the windshild that is causing it.
Old Jan 28, 2007 | 11:56 AM
Mike Mercury
WOW !!! my 2002 isn't anything like that (non-HUD built car). I wonder if at some point in C5 production that all C5's got the HUD windshield ???
Old Jan 28, 2007 | 03:29 PM
JEEP/C5's Avatar
JEEP/C5
I have noticed at when I wash the inside of my windshield that right above where the HUD is located the window dips in slightly, perhaps it changes the angle slightly to make it easier to read from the drivers seat?
To Windshield Question
