See that streak.Its run's up from where the exhaust valve goes into the valve guide,Then out the exhaust.Its a clean path through the carbon.Could it be sucking coolant or oil? Or leaking valve seals? My pistons still have carbon on them.My plugs looked normal.
How did your oil look? Any overtly high oil usage? Is the car burning coolant?
IMHO burning the oil through the valve seals would leave it dirtier and thicker coating on the exhaust. Do you have a PCV setup or running a breather? Are you spraying this setup? What cam is it (valve events) and springs?
You say this streak runs from the intake valve up to the valve guide?
If you can see the intake valve thru the exhaust port then you've got bigger problems than a clean streak.
Seriously, something is probably leaking thru the exhaust valve guide, most likely oil, did you find this while doing other work or were you investigating a problem?
What kind of valve seals do you have and how old are they?
Interesting, I am curious about this too!
Its happening on 7 cyl. PP heads w/there springs & 233/239 595-603 cam.I should have said exhaust valve in 1st post,I'll fix it I've had this setup for about a year and I never added coolant,Come to think of it it was alway's on the full mark.I had the car on a dyno and no white or blue smoke came out the back, I have a PCV setup and I just added a catch can about a month before I took it off the road.I'm wondering if it was a one time thing that happened or after I added the catch can hmmmm.I had to put a half a qt. of oil once in awhile.I had no problems with the motor,Found this doing other work.No spray.Is it possible for coolant to go between the guide and the head?Now that I think about it,Coolant is the only thing that would leave a clean mark.
I talked to a guy once that insisted that it's possible for aluminum heads to get a 'pinhole' from porting. He said that due to the sand in the casting that you could get a very thin wall at the waterjacket in spots because the sand, or air bubbles, get in the casting near the walls. If that happens you could pop the wall and get a dribble...
I don't know if this applies, just sharing a possibility.
Small UPDATE so far I found a ripped valve seal on exhaust side.Its hard to see in that picture but its there.I hope thats all it is.I'll take apart the other one's and see. UPDATE again. Well thats not it,The rip did not go all the way through,Its got to be coolant seeping through.Is there any fix for that ,Maybe put some kind of sealant in the Rad. Or would I have to have the guide pressed out and fixed that way?
I would get a hold of Gunnar @ Patriot....get them ( or another shop ) to pressure test the head.
I've read some good experiences with thier customer service...see if they come through.
Thats what I did,I called Gunnar He told me to send the heads down to him and he will check them out.I don't want to put the heads back on like that.I have till March anyway till racing starts .............Paul
You say your coolant level is always on the full mark yet everyonce in a while you have to add a 1/2 quart of oil ...do you still think it's coolant?
Any liquid passing at a high rate of speed over a sooty piece of metal will clean it, I say throw some new Viton valve seals on and forget it.
I wish it was the seals,But its coming through where the guide is pressed into the head.I'm going to look at again and take another exhaust valve out.Would there be oil on the valve stem if it was the seals?......................Paul
Good news ....I'm sure they will find your problem
I think it is the seals.I looked at it closer and it was clean right where the valve goes into the guide and it was kind of wet with alittle oil.I took the valve out slow and it had a tiny bit of oil on the whole stem.Now where do I get Viton seals.Whats the worse that could happen,I'll check it again after I run it a few times and see if its still there.........Paul
I've bought the seals from both Comp cams and Thunder Racing, they're very reasonably priced usually around $15.00 for a set.
