replaceing harmonic balancer
Old Jan 30, 2007 | 12:54 PM
deckx's Avatar
deckx
Navigator
Default replaceing harmonic balancer
My harmonic balancer walked toward the engine. I take it I need to replace the balancer, or ???. If I need to replace it can anyone give me step by step instructions on how this task is done.
I have a 1999 vette.
Old Jan 30, 2007 | 01:27 PM
Tmyz 2K's Avatar
Tmyz 2K
do a search. there are plenty of threads about it. for pictures and info on how to do it,
www.ls1howto.com
go to the c5 heads/cam page, its very helpful.
i dont this a few weeks ago, and it took my just under 6 hours working slowly and with a handful of breaks.
Old Jan 30, 2007 | 08:15 PM
Casem1's Avatar
Casem1
Do you mean it walked away from the motor???
Old Feb 7, 2007 | 08:41 PM
deckx's Avatar
deckx
Navigator
no, towards the engine.
Old Feb 7, 2007 | 10:02 PM
Bunk930's Avatar
Bunk930
2018 C6 of Year Finalist
This is a major operation, at least for me.The steering rack has to come down to get the HB off. I took mine to a dealer and the labor was about $600.00. The way I see it that was money well spent.
Old Feb 7, 2007 | 10:12 PM
donkelso's Avatar
donkelso
I recently did this job on my 2000. There is a pretty good procedure with pics at www.magnacharger.com on how to access the HB. Their procedure is written to install their supercharger, but it gives good guidance on how to pull the steering rack and get to the HB. Took me a full day to do the job. You will need a good puller and a tool to press the new balancer on. You can make one with threaded rod. Do a search on this forum and you will find info on what one looks like. Hardest problem I had was breaking the crank bolt loose. Good luck.
Old Feb 7, 2007 | 10:17 PM
aquachuck1's Avatar
aquachuck1
Default Harmonic balancer
I believe Magnuson has their installation manual on line.....it will give you a detailed, step by step approach to taking everything out to get to the balancer.
Thing you may need.....torque wrench that at least goes to 240 ft/lb(that is the factory setting). I used a 4 foot length of pipe to put over my breaker bar to get the bolt broken free (I have a stick and you can put it in 4 th gear to break the bolt...slow steady pressure on the bar will do it). The bolt is either a 23 or 24 mm .
when you have the balancer off...suggest you change the timing cover/crank oil seal, you dont want to have to do this procedure over again when the seal goes.
A lot of little hurdles to over come doing it....but well worth the savings of $600.00
Old Feb 7, 2007 | 10:19 PM
Bunk930's Avatar
Bunk930
My car had about 67000 miles on it when the HB went bad. How mant miles did your car have on it?
Old Feb 8, 2007 | 12:20 PM
pylant's Avatar
pylant
I put a new fluid damper on mine a couple of years ago.
It is work..took me all day (6-8 hours) at the local self help shop.
A couple of points. If you have the right size puller you don't have to remove the radiator. You will need to remove the puller and tap off the HB the last inch or so. No big deal, just good to know info.
Use your old bolt to install the new HB. Then use a new bolt for final Tq.
Remove the starter and use a large screwdriver to hold the flywheel while Tqing the bolt.
When putting the steering rack back in make sure the metal liner in the rubber mounts are lined up correctly. I beat the crap out of them trying to get them back in until someone pointed out the metal liner was not lined up. Fix right in easy then.
Just a couple of hard lessons learned.
Old Feb 8, 2007 | 12:42 PM
thehammer69's Avatar
thehammer69
Curious...how did you like that Fluidampr after the install?
Hammer
Old Feb 9, 2007 | 10:43 PM
pylant's Avatar
pylant
Hammer
I got to say I have loved it. Before the install my OE HB had and obvious wobble. I was told to not worry about it from a dealer service department but it just looked awful. I could just see the dang thing flying off and taking out my radiator. I shopped hard before I decided on the fluidampr, i.e. rattler, OE, etc. I think it smoothed out the engine in the RPM (normal) range that I run so I went with it.
By the way, after the install the serpentine belt was rock smooth. How sweet!
Old Mar 5, 2007 | 12:22 PM
J.M.G.'s Avatar
J.M.G.
On the 2002 the starter is hold by 2 13mm bolts. 1 can be reached easily, however, the other one is covered by the right pre-cat. How do I remove this bolt?
Old Mar 5, 2007 | 12:37 PM
94legaleagle's Avatar
94legaleagle
Have to move the pre-cat out of the way - been a while since I've had stock exhaust, but you might have to remove the "H" pipe to get access.
Old Mar 5, 2007 | 02:20 PM
J.M.G.'s Avatar
J.M.G.
Thank you!
I guess in that case I'll take a closer look on this tool:
To replaceing harmonic balancer
