Seat won't go back
Old Feb 1, 2007 | 01:02 AM
ROD BROWN's Avatar
ROD BROWN
Default Seat won't go back
I am having trouble getting the seat on the drivers side to retract when I get out of my 2006.Anybody help?The seat goes forward,but won't go back when I shut the engine off.I can't figure out what I am doing wrong.
Old Feb 1, 2007 | 08:02 AM
65GGvert's Avatar
65GGvert
Splain some more. Do you mean the button won't slide the seat back or the seat doesn't retract automatically? If it's the second one, are you removing the key? Just shutting the engine off won't make it retract. On the DIC, do you have the easy entry/exit set to "on"? Need more info.
Just reread your post: Don't know nothin' bout no 2006, maybe the C6 forum could answer
Old Feb 2, 2007 | 01:02 AM
ROD BROWN's Avatar
ROD BROWN
The seat won't go back automaticllywhen I turn the engine off.I have the easy entry/exit set to the on position.there isn't any key to remove
Old Feb 2, 2007 | 01:08 AM
BlackZ06's Avatar
BlackZ06
You're probably better off posting this in the C6 forums
Good luck
To Seat won't go back
