supercharger !!! dyno numbers .......
Old Oct 4, 2001 | 09:06 PM
99vortech's Avatar
99vortech
Default supercharger !!! dyno numbers .......
Just put the car on the dyno for the first time..........leaned out at 5000 rpm's.....still made 466 rear wheel hp..........anyone know if larger injectors and fuel pump will help ? Best place to get injectors and fuel pump ???
Old Oct 4, 2001 | 09:20 PM
CMilVette's Avatar
CMilVette
Default Re: supercharger !!! dyno numbers ....... (99vortech)
Damn, awesome numbers man! :yesnod: :yesnod: :yesnod:
Old Oct 4, 2001 | 11:06 PM
robsvette's Avatar
robsvette
i have seen cartek place in larger injectors in C5PIG's. i don't know where they got them from though.
Old Oct 5, 2001 | 02:18 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
summitracing.com or also try rceng.com for injectors.
If your C5 is a 97-98 you have an adjustbale fuel pressure regulator that can be used to increase pressue, which would increase the capacity of the injectors.
Old Oct 5, 2001 | 09:19 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Good numbers!!
Which SC kit is this? How much boost? Completely stock engine?
Old Oct 5, 2001 | 09:22 AM
99vortech's Avatar
99vortech
Default Re: supercharger !!! dyno numbers ....... (MattG)
Vortech(caroll) kit......stock motor......9 psi......
Old Oct 5, 2001 | 10:20 AM
thekev_2000's Avatar
thekev_2000
I have the 42# in jectors with my stage 4, but do not have a stock engine; I think you can adjust your fuel a little with the SuperPumper module. Call Greg Carroll directly, tell the admin person that answers, Sheryl, that you have a VERY technical question and need Greg ASAP! Good Luck
Old Oct 5, 2001 | 10:33 AM
VetteVert's Avatar
VetteVert
Default Re: supercharger !!! dyno numbers ....... (kewlbrz)
Hey Kewl, where can I find more info on the adjustable regulator on 97-98's? Can I use it to tune/tweak such minor modifications as mine? Would there be any need?
Thanks!
VV
To supercharger !!! dyno numbers .......
