center console lock
Old Feb 3, 2007 | 10:17 AM
oldschoolvette's Avatar
oldschoolvette
Default center console lock
Is this cylinder a match to the ignition or will any vette key open it. Has anyone ever tried to get a new lock cylinder from GM? thanks
Old Feb 3, 2007 | 11:35 AM
B-rent's Avatar
B-rent
Mine doenst lock with the car key, im assuming its broken and should though
Old Feb 3, 2007 | 11:37 AM
Oldvetter's Avatar
Oldvetter
Although it doesn't use all of the tumblers of the ignition lock, I imagine it is a match to the ones it uses.
Old Feb 3, 2007 | 11:48 AM
TEXHAWK0's Avatar
TEXHAWK0
I wouldn't worry about a key to lock the console. That lock is only good if you want to keep a 3 year old out anyway.
Old Sep 11, 2013 | 05:27 PM
ESB-LS2's Avatar
ESB-LS2
my key turns the cylinder but lock mechanism. do I have to take the console out to repair th link mechanism or is there away from the inside of the console? thanks for your help!
Old Sep 11, 2013 | 06:17 PM
Ho0osierdaddy's Avatar
Ho0osierdaddy
The lock has a clip that holds it in. Just pull it up or pry it up and off
To center console lock
