getting car on 4 jack stands
Old Feb 3, 2007 | 03:29 PM
Marcs c5's Avatar
Marcs c5
Default getting car on 4 jack stands
How do I go about getting my car on all 4 jack stands(2003 Z06)? I have never even put a jack under my car yet so I don't know where I should be jacking it from. I have read that I will need to drive up onto some 2x6's so I can get the jack under the front.
Old Feb 3, 2007 | 04:44 PM
BanditDude's Avatar
BanditDude
Check out this post.
http://forums.corvetteforum.com/show...jacking+points
Old Feb 3, 2007 | 04:47 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
buy a set of rhino ramps. They are easier to use and if you are not familiar with jacking the vette you might find it hard without a low profile jack...
Old Feb 3, 2007 | 05:00 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Oh sure include ECS on everything you write about.
Im joking before I catch a flamer
Old Feb 4, 2007 | 01:07 AM
Bill Dearborn's Avatar
Bill Dearborn
I jack one side of the car up at a time at the front shipping slot. Once the jack is up high enough to take the rear wheels about 5 inches off the ground I put jack stands under the front and rear cross members on that side. Then I go to the other side and jack it up the same way and put jack stands on that side. If I want the rear higher I then jack from the middle of the rear cross member and adjust the rear jack stands appropriately. If you have a long nosed low body jack that can get under the car to lift the front by the crossmember then you can forget jacking from the side.
Bill
Old Feb 4, 2007 | 01:38 AM
gpotski's Avatar
gpotski
See this thread...
http://forums.corvetteforum.com/show...g&forum_id=103
To getting car on 4 jack stands
