Will it handle it?
Old Feb 4, 2007 | 11:29 AM
LAYNLOW's Avatar
LAYNLOW
Default Will it handle it?
Assuming the car is not beat on a regular basis.
Assuming it's always running 100+ octane.
Assuming the car is tuned and maintained regularly.
IYHO: Do you think a stock bottom end 2004 LS1 with 3000 miles can handle 525 RWHP? The car is currently at 475 RWHP on 6lb of boost.
Thanks!
Old Feb 4, 2007 | 11:35 AM
CHJ In Virginia's Avatar
CHJ In Virginia
You probably probably would get better input in the FI / Nitrous section based on what the guys are actually running. Even with higher octane fuel, much higher boost will cause problems. With higher boost and stock internals / compression ratio usually = grenaded engine or holes in pistons.
