Wheel hop fix
Old Feb 5, 2007 | 11:21 PM
Quickshift_C5's Avatar
Quickshift_C5
Default Wheel hop fix
Hey guys, title pretty much says it all.
Experiencing loads of wheel hop from the IRS. I haven't seen a whole lot of people talking about bracing it or doing anything special like I do with Cobras and GTO's.
What do you guys do to tackle this problem?
Old Feb 5, 2007 | 11:53 PM
2fat2fly's Avatar
2fat2fly
I hope these links help your wheel hop issues.
http://forums.corvetteforum.com/show...post1558723132
http://forums.corvetteforum.com/show....php?t=1610316
http://forums.corvetteforum.com/show....php?t=1603653
http://www.dynotech-eng.com/dte_c5_diff_strut.htm
I have the same problem and have been doing extensive research.These are some of the things I'm doing to tackle the problem:I'm installing a line lock to get my drag radials a better burn out.I will be going with 17" drag radials on a spare set of Z06 front rims,doing away with the 18" drag radials.The last thing I am installing is a set of QA1 adjustable shocks for the rear.I believe these changes will eliminate my wheel hop problem.
As safety measures for the survivability of the rear end I will be installing hardened output shafts in the rear axle and the DTE(Dynotech Engineering) rear end strut kit.
Old Feb 6, 2007 | 09:02 AM
EHS's Avatar
EHS
Lift off the throttle.
Old Feb 6, 2007 | 02:11 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
[QUOTE=Quickshift_C5;1558833964] [QUOTE]
Are you on runflats? I stopped hopping when I switched to Michelin non RF's
Old Feb 6, 2007 | 02:20 PM
robert123's Avatar
robert123
A lot of people seem to agree the runflats a big contributer. Some people say shocks also help. Any way you look at it , there is no real cheap fix.
Old Feb 6, 2007 | 02:26 PM
zeevette's Avatar
zeevette
My non-funflat F1 SCs hopped like crazy, and so do my current Michelin Pilot Sports.
Old Feb 6, 2007 | 04:11 PM
2fat2fly's Avatar
2fat2fly
Ditto Firestone Wide Ovals.
To Wheel hop fix
