Really Weird Headlight/HID install issue...
Old Feb 6, 2007 | 03:50 AM
jpandes's Avatar
jpandes
Default Really Weird Headlight/HID install issue...
I tried installing some "plug and play" 9006 HID's today. The problem that I encountered was that my lights would not go up and down correctly after installiing the HID's. They'd either go down part way and stop, as if there was something blocking the mechanism. I checked and tripled checked to make sure that the wiring and ballasts were positioned correctly. I also thought that I messed something up by manully raising/lowering the headlights and then cycling the switch.
I finally gave up thinking that I fried my pop-up motors and was going to take the car to the dealer and "play dumb" and just let the extended warranty pay to fix the headlight motors... Well, while I was removing the HID bulbs and ballasts, and after I reinstalled the factory 9006 bulbs, the headlight motors began working again.
Now, I have one HID and one OEM halogen bulb. The lights go up and down just fine. I'm guessing that there is a voltage issue with the HID ballasts powering up and not sending the correct signal to the headlight motors. Has anyone else had this issue? Any suggestions? I'd like to get the other HID working...
Thank you in advance,
John
Old Feb 6, 2007 | 04:16 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Curious for an answer also. These sorts of things are why I've never raised mine manually when working on them. Seems to darn near always cause some sort of issue?
Old Feb 6, 2007 | 09:46 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
common problem with "bulb swap" HID kits.
Old Feb 6, 2007 | 10:31 AM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
I just read from an earlier post that you got them off e-Bay for $130. You really get what you pay for these days. NTRBL33 is a supporting vendor here and has a great set for $299. He worked with the manf. to come up with best ballast with relays built in and bulbs that fit the socket better.
Old Feb 6, 2007 | 11:37 AM
RPOZ4Z's Avatar
RPOZ4Z
you're right, you do get what you pay for.........
and here's what you get:
wether you spent $130.00 or $299.00, you get light that goes everywhere except down the road, where you need it, blinding oncoming traffic and not to mention the fact that they're illegal and won't pass state inspection (if you're state requires one).
and the HID bulb swap kit in the pic is in the "better" glass euro headlight housings, the glare will be worse with the stock plastic housings.
and here's what it should look like.........
Old Feb 6, 2007 | 11:47 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i really need to take my own pic of the "garage cutoff" so i can stop stealing yours.
Old Feb 6, 2007 | 12:09 PM
DavzC5's Avatar
DavzC5
My HID (bulb swap) looks just as the stockers light pattern - except more white and further down the road and if aligned correct NO one flashes that its a problem.
Stock bulbs..
HID bulbs..
To me I wouldn't pay more than $300 for them anyway. But we all have opinions.
Old Feb 6, 2007 | 12:44 PM
jpandes's Avatar
jpandes
I didn't know that this was a "common problem." I have purchased two other HID kits for ~$300 bucks for my previous car, RX7 with pop-ups and had no issues at all. One thing that I need to try is to reinstall the other HID and try raising or lower the lights with the engine running. Maybe the additional voltage from the alt. will help out. Otherwise I will have to add a 30 AMP relay into the mix.
Does anyone have any other suggestions?
Old Feb 6, 2007 | 01:42 PM
DavzC5's Avatar
DavzC5
I have never heard of any "common problem' either. I don't really understand why motor isn't working correctly. Your only using the car bulb power plug right? and the HID should only draw 3.5v to start up compared to like 11v of reg bulbs. I wouldn't do any changes with the car on..disconnect the battery for sure or you might blow a ballast.
Old Feb 6, 2007 | 02:32 PM
jpandes's Avatar
jpandes
Correct, I am only plugging the ballast into the bulb plug. I'll try things again tonght. It should work. This is not rocket science!
Old Feb 6, 2007 | 04:35 PM
cjs27410's Avatar
cjs27410
Try switching to high beam before you turn off the headlights. That worked for my HID bulbs.
Old Feb 6, 2007 | 04:47 PM
jpandes's Avatar
jpandes
Thanks. I'll try that.
Old Feb 6, 2007 | 10:14 PM
RPOZ4Z's Avatar
RPOZ4Z
that's the "solution" to the common problem, not all bulb swap kits do it, mine didn't, the headlights worked normally.
Old Feb 6, 2007 | 11:43 PM
DavzC5's Avatar
DavzC5
Dude, what happened? Did you get the pop ups working?
Old Feb 7, 2007 | 12:20 AM
EHS's Avatar
EHS
Correct, common problem. It's the wiring harness.
www.partsforyourcar.com were selling some old wiring harnesses that did that.
Insist on a free replacement that works. Speak with Brian Marks there -- he knows about the issue.
Old Feb 7, 2007 | 02:37 AM
jpandes's Avatar
jpandes
What wiring harnesses are you talking about? The harness that goes from the ballast to the bulb plug? I have a spare set of 9006 wire harnesses that I can try.
Old Feb 7, 2007 | 03:06 PM
C5 ChemE's Avatar
C5 ChemE
Same issue here and this works great for me.
To Really Weird Headlight/HID install issue...
Old Feb 7, 2007 | 07:19 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Does anyone have a comparison between the bad and good wiring harnesses?
A couple of guys just installed HIDs and had no complaints about this....
Old Feb 7, 2007 | 09:08 PM
Confused4yrs's Avatar
Confused4yrs
1st Gear
You need to power the ballast from the battery through a relay, instead of just plugging the headlamp plug to the ballast. Then use the headlamp plug to control the activation of the relay, the light will pop up and go back down as normal.
This site may help explain. The wiring diagram about halfway down the page is the one that I've used, but it's a good idea to read most the writeup. It will help make since of why it should be wired this way. http://faqlight.carpassion.info/headlamp-harness.html
Old Feb 8, 2007 | 01:58 PM
JCOB2's Avatar
JCOB2
This is exactly how I wired my setup, and I still occassionally get the "no-down" problem. To me, it's not worth troubleshooting any further, and I just do as others here have recommended. Flick the brights on, and the lamps go down!
