Coil Pack Issue
Old Feb 7, 2007 | 04:44 PM
Casem1's Avatar
Casem1
Default Coil Pack Issue
After just doing a little work to the car (hehehe, a majority of the driveline was removed) I am having a intermittent problem. First all of my passenger side coil packs started throwing codes (P0352, 4, 6, 8) and I started to hear some misfires. I unplugged the big connector to the coil packs, ensured it reconnected tightly and the codes and the misses go away. A few 'drives' later I start missing bad under acceleration, seem fine at cruise (over maybe a half mile of limping home) then the car dies. This time all 8 coils throw a code (P0351-8). I do the same thing (unplug, reconnect) and it then runs fine.
Whats up with this, guys? I never had a problem with these before!
I don't want to have to hit the 'reset' button after every few miles....
Old Feb 7, 2007 | 07:00 PM
dpd's Avatar
dpd
grounds on back of the cylinder heads/block loose? wiring harness on left side rear head[ where bracket is]rubbed through?
Old Feb 7, 2007 | 07:17 PM
FRCTony's Avatar
FRCTony
Old Feb 7, 2007 | 07:48 PM
Casem1's Avatar
Casem1
I recrimped it as the original ring was corroded snapped off. I will check it out...
Thanks guys
Old Feb 9, 2007 | 06:21 PM
Casem1's Avatar
Casem1
That was it! It worked itself out a little bit and was hit or miss connection wise.
To Coil Pack Issue
