E-Brake Problem
Old Feb 7, 2007 | 09:33 PM
wilson34's Avatar
wilson34
Default E-Brake Problem
My emergency brake does not catch until the very very top, what could be the problem and how can i fix this?
Old Feb 7, 2007 | 10:05 PM
TEXHAWK0's Avatar
TEXHAWK0
Brake pads not adjusted right. You will have to pull the rear rotors to adjust the clearance on the brake pads. You can do a search and find a description of how to go about it.
Old Feb 8, 2007 | 01:08 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
https://www.corvetteforum.com/techti...=158&TopicID=1
P.S. Think of it as a parking brake or you will be sorely disappointed the first time you try to use it in an emergency.
Old Feb 8, 2007 | 01:27 AM
Bill Dearborn's Avatar
Bill Dearborn
Before adjusting the brake shoes try this.
From the Service Manual: Cycle the park brake lever three times in order to obtain proper park brake cable tension.
Bill
Old Feb 8, 2007 | 01:30 AM
jbauch357's Avatar
jbauch357
Never trust the parking brake alone, always put it in gear when parking - or you might have the car take a ride without you like I did...
Old Feb 8, 2007 | 04:05 PM
wantmyc5's Avatar
wantmyc5
Same thing happened to me when I was dropping the car off for an alignment!! Needless to say I had them adjust it there. When I saw the bill for the adjustment I was shocked and only then did I realize what was involved in the adjustment on these cars - not like they used to be!
Old Feb 8, 2007 | 04:45 PM
dbelnap's Avatar
dbelnap
Default In the middle of replacing the parking brake shoes
I have had the same problem for much longer than I want or should. Parts are now on order. The straw that broke "my" back was when the car rolled down my ever so slight drive way and it was a comedy of errors trying to get it stopped before crossing the street and hitting the neighbor's mail box!
I have researched this site to death and posted lots of questions with lots of info coming back. (search on Parking Brake) I have taken the rear rotors apart and feel that after all is said and done, I need new brake shoes, cable seems to functions OK, I can get the rotor back on just so tight (before it won't clear the parking shoe) and still cannot get the sucker to work. Therefore, ordered new shoes. All I can currently get with old shoes is a bunch of squealling when the p-brake is applied.
Also, p-brake is on both sides of the rear rotors, not just the passenger side, so try adjusting the star nut on both sides.
Regards Doug B
Old Feb 8, 2007 | 09:43 PM
LoneStarFRC's Avatar
LoneStarFRC
No such thing as an "emergency brake". Kinda like "sway bars" too; they don't exist.
Old Feb 12, 2007 | 12:32 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i just got done installing my new rotors. i have also just adjusted my parking brake because i could pull it all the way up to 90* and it would still not hold the car.
here you can see the little adjuster thing.
i started out with zero gap between the top of the adjuster and the body of it. by knocking the little notches back with a flathead screwdriver and a hammer, i was able to extend the body until the new rotor fit snugly on it but still turned freely.
the e-brake handle now comes fully engaged at 45* or so and i CANNOT push the car in neutral anymore.
Old Feb 12, 2007 | 12:54 PM
DefenderC5's Avatar
DefenderC5
1st gear is your best parking brake
To E-Brake Problem
