Z06 Brake Coolers
Old Oct 5, 2001 | 04:12 PM
C5SilverBullet's Avatar
C5SilverBullet
CI 4, 5 & 9 Veteran
St. Jude Donor '08-'09-'10
Default Z06 Brake Coolers
Are they hard to install, and/or is there a lot of cutting?
Old Oct 5, 2001 | 04:38 PM
Jd3's Avatar
Jd3
From: Time flies like an arrow...fruit flies like a banana
Cruise-In I Veteran
Default Re: Z06 Brake Coolers (C5SilverBullet)
I haven't done it personally, but the brake coolers that Doug Rippie sells for front brakes aren't too bad to install from what I understand...
Old Oct 5, 2001 | 04:50 PM
COOL Z06's Avatar
COOL Z06
The GM Z06 vents require cutting and drilling the rocker panel to mount the scoops and to make them functional. You also have to cut or notch the rear wheel liner panel to allow ducting of the air from the scoop to the wheel.
It's really not that bad of a project if you have the right tools and some patience.
Old Oct 8, 2001 | 06:48 PM
Vettenam's Avatar
Vettenam
I really like the way they look, but kinda scared to cut my baby. I heard of some "stick on" types. Any info to where to buy them? Also how good do these "stick on" types hold up at high speeds, rain...ect.? Any info is appreciated. :cheers:
Old Oct 8, 2001 | 10:26 PM
Joel Fromkin's Avatar
Joel Fromkin
Forget the stick ons. The Real ones are easy to put on. They take about 45 minutes for each side. I would order the whole kit from west coast corvette. It comes complete with the vents,ducts and inner fender wells. I think its about $239 or so. :yesnod:
[Modified by Joel Fromkin, 8:27 PM 10/8/2001]
Old Oct 9, 2001 | 03:16 AM
MikeyD's Avatar
MikeyD
Default Re: Z06 Brake Coolers (Joel Fromkin)
$135 from LAPD for the genuine scoops and ducts for both sides. No templates though. Easy to do. You just need patience and a strong stomach :D :cheers:
[Modified by MikeyD, 1:17 AM 10/9/2001]
Old Oct 10, 2001 | 03:08 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
St. Jude 15 Year Donor
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08-'25
Default Re: Z06 Brake Coolers (MikeyD)
Mine arrived today from LAPD and no instructions or tmeplates!?! They told me to ask one of you who have installed before what is needed to do a clean install. They also spoke about measurments of Z06 ducts and vents? Any help would be most appreciated. Not trying to make a big deal of a basic simple install, yet I want to measure twice and cut only once!! Please be specific with advice. Thanks alot guys. :flag
Old Oct 10, 2001 | 09:19 PM
conawayw's Avatar
conawayw
Default Re: Z06 Brake Coolers (Nitro-C5)
I too just recieved my cooler with ducts, no instruction. I'm making a template and will cut it out using cardboard as a test. Did you use any sealer to the body once you installed them? I'm also going to take some pictures as I install them this weekend for anyone else who wants to do this. ;)
Old Oct 10, 2001 | 09:41 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I installed my rear brake ducts myself.. from a Kit from LAPD.... they are Breathless performance ducts... they have twice the cooling surface as the Zo6 type and they sit inside the rocker and look more factory.. they also come with a template.. Make sure you use wide masking tape to tape off all the painted surface of your dorr and rocker so when you use a jig saw to cut the rocker , you do not scratch the paint.. You do NOt get inner wheel wells with any kit.. cutting one rocker takes about fifteen minutes with a template.. iif you do not have a twmplate.. there is little room for error.. so make sure you lay it out right.. removing the inner wheels well takes five minutes.. cutting them will be tough without a template.. you need some points of reference.. once you put the ducts on ( One bolt holds them .. ) Clearance at the wheel well is critical for a clean install ...
Old Oct 11, 2001 | 08:13 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
Cruise-In V Veteran
Default Re: Z06 Brake Coolers (Evil-Twin)
Anyone else out there with some good advice? Any specific mesurments need to be aware of befroe I start cutting? More responses please, i know more people have done this mod. Thanks again...
:flag :flag
Old Oct 12, 2001 | 01:19 AM
MTWallet's Avatar
MTWallet
I have some advice for LAPD...
MAKE A TEMPLATE AND INSTRUCTIONS AND SEND IT WITH YOUR DUCTS!!!!!:mad
How about if someone sends their template to them and they duplicate it on heavy posterboard so they can sell a COMPLETE kit! This doesn't sound too hard to me. :confused:
Old Oct 12, 2001 | 01:26 AM
ScreaminDemon's Avatar
ScreaminDemon
I don't have them but I believe the Breathless ones are bigger. I think they would look good on mine if painted to match. :seeya
Old Oct 12, 2001 | 02:27 AM
Evil-Twin's Avatar
Evil-Twin
Default Re: Z06 Brake Coolers (ScreaminDemon)
I believe they would look like mine... BTW you can not use the template from these ducts.. for the Z06 ducts..
Old Oct 12, 2001 | 04:25 AM
MikeyD's Avatar
MikeyD
The scoops and ducts are not bad to install. The only trick as everyone has pointed out, is getting a good template. I made my own out of cardboard. It worked pretty good but I ended up having to tweak the holes after the first initial cut. Thats O.K. though as I'd rather have too small a hole than I one that is too big. I think I still have the template somewhere if someone would like to have it. Its too big to fax so I'd have to send it by mail. As the pics show, the duct itself requires a small section to be cut out of the inner fender skirt but its real easy to cut. I used a pair of heavy scissors. Also, the duct mounts using an existing mounting screw for the inner fender skirt.
[Modified by MikeyD, 2:31 AM 10/12/2001]
Old Oct 12, 2001 | 10:52 AM
Nitro-C5's Avatar
Nitro-C5
Moderator
Cruise-In V Veteran
Mike,
I would love to have that template!!!! FED-EX it to me and I'll pay you back, i promise! :blueangel:
My address is:
Rick Bell
3640 Arklow Rd.
Charlotte, NC 28269
Thanks alot in advance :seeya :cheers:
Old Oct 12, 2001 | 12:22 PM
PhiloMcGiffin's Avatar
PhiloMcGiffin
Rick... I'm getting a template from a forum member (any day now) it was provided by West Coast Corvettes as part of their package... No flames, but Mike's install, while it looks good... is not correct... if you measure the distance of the scoop from the door and the horizontal seam on a Z06 it is uniform and of a greater distance than as shown on Mike's car... in other words, his scoop is too far forward... Mike it looks nice so don't be offended!
I'd be happy to share the template with you if you are interested... let me know off list.
Good Luck!
Philo :seeya
Old Oct 12, 2001 | 12:52 PM
MikeyD's Avatar
MikeyD
Default Re: Z06 Brake Coolers (PhiloMcGiffin)
No offense taken Philo. :cheers: The problem with these scoops and trying to install them is that they go into the hole at an angle so you have to compensate for that...at the beginning. Unfortunately, by the time I got the hole cut, the scoop ended up a little closer to the front than I wanted. Once you cut the hole to size, its a little late to do anything about it. The edge of the scoop is right up to the hole you cut. No room to adjust without having a big gaping hole to the side of the scoop. Oh well, nobody would notice unless they're a Z06 guru. :yesnod: And thanks for noticing :lol: :lol: :lol: :lol:
Just joshin ya :lol: :cheers: :cheers:
To Z06 Brake Coolers
Old Oct 12, 2001 | 07:14 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
Cruise-In V Veteran
I would love to have this template can you send one to me by FED-EX. My address is at the post above yours. You the man! I will owe you a....
:cheers: :cheers: :cheers:
Rick :flag
Old Oct 13, 2001 | 11:00 PM
conawayw's Avatar
conawayw
Well I did one of the coolers this afternoon. It took some courage to cut the body. Looks great will do the other one next Sat., have to do some things for the wife. :smash:
Old Oct 13, 2001 | 11:35 PM
ScreaminDemon
That wouldn't be as noticeable if you'd paint em' to match! Looks good...... :seeya
