Re: MAFT Users What are your current settings? (EasyGoin)
-15 -10 = 25% lean
SVO 30 injectors, LS6 manifold, cold air box, no screen stock MAF, custom pistons, custom heads and cam.
11.3:1 compression with long tubed headers.
Billeted and Molly 4340 parts that are cooled via a heat exchanger, race radiator and 2 quart AccSump to protect oilpan issues.
Re: MAFT Users What are your current settings? (team-zr1)
Chuckster, can you report back what you find is the optimal setting with the headers? ;) Would be interesting to see how much change is caused by the headers. Thanks. :cheers: By the way, mine is at +5% Base/+4% WOT
Re: MAFT Users What are your current settings? (chuckster)
I look at the MAFT together with the AutoTap software as a very good temporary tuning solution. When you have everything working perfectly take your MAFT settings and your computer to one of the many tuners and have it reprogrammed to reflect the MAFT settings. Now you can run without the MAFT having one less part that can fail. My $0.02
I also found problems with 'sudden power loss' or strange dyno results with dips at certain rpms. I wrote a instruction about how to mod the MAFT to avoid these problems. I can't find it in the archives but kewlbrz has put together this info on his website at http://www.vetteguru.com/mods/maf/
