Tire Sensor Problem ????
Old Feb 8, 2007 | 07:26 PM
speedy77's Avatar
speedy77
Default Tire Sensor Problem ????
Hello....When driving car for about 1/2 hr. (highway driving, only time it does it). I get a message telling me R.R. sensor not detected. When I clear it out, then restart car it seems fine. Other then that I always get a pressure reading. Is the sensor bad ? It's been that way since I got the car 4 yrs ago. Thanks
99' FRC
Old Feb 8, 2007 | 07:58 PM
TopFuelTim's Avatar
TopFuelTim
Default Does it have the original TPS's
If it does, most likely the batteries are starting to expire. Happened to mine, although three were working OK, one began to act up. I just replaced them all since I was getting two new tires and was at the tire shop. Be prepared. They are definitely not cheap. Paid $348 total from Fichtner Chevrolet, although Gene Culley or Fred Beans can also treat you well.
Tim Glover
Old Feb 8, 2007 | 08:23 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Sounds to me like it may be something other than the batteries if it has been doing it for 4 years. The battery surely would have expired before now.
Old Feb 9, 2007 | 06:07 AM
speedy77's Avatar
speedy77
Can just the batteries be replaced ?
Old Feb 9, 2007 | 08:22 AM
bluvette79's Avatar
bluvette79
some folks on this site have changed them but it involves cutting them open. there is also an inertia switch that turns the battery on when the wheels roll that may also cause your problem. i don't know the longevity rate with a replaced battery. i would replace the tps if it were me but i am getting lazy in my old age!
jim
To Tire Sensor Problem ????
