code p0758 ,,,help plz
Old Feb 9, 2007 | 12:15 PM
MRC5's Avatar
MRC5
Default code p0758 ,,,help plz
I'm getting this code. (( p0758)) the car wont shift to 4th gear , and if gear got hot it wont shift down to 1st gear . i did change the soiliniod but it didnt help ,also the car shift realy hard now , what cause this and what's the fix ?
Old Feb 10, 2007 | 08:12 AM
MRC5's Avatar
MRC5
anybody plz ???
Old Feb 10, 2007 | 10:41 AM
dpd's Avatar
dpd
you're running in fail safe [third gear only/high line pressure].your fault is for a electrical problem with the 2/3 shift solenoid.you didn't mention if you have any other faults along with the 758.if you do.check the fuse[i think it's 19 under the hood].the easiest way to check the circuit is with a scan tool and do a output test on the solenoid.with the key on,engine off you can command the solenoid on/off.you should here it click on/off in the tranny pan.
Old Feb 11, 2007 | 09:05 AM
MRC5's Avatar
MRC5
thank dude ...im going to check that ..
i got p0754 but its gone , now im only got p0758 code. thats problem shown after sawpn' the pcm . i didnt' mention any problem just the grear shift and looks like converter lockup all time , if gear got hot it dosest shift down to fist gera , i have to shift manual , the gear shift so hard ....
To code p0758 ,,,help plz
