Different Fuel Gauge problem
Old Feb 9, 2007 | 12:47 PM
C5Longhorn's Avatar
C5Longhorn
Default Different Fuel Gauge problem
My fuel gauge problem is different than most reported here. When I fill up completely, the gauge does not return to full. Instead its only 7/8's full.
Anyone have this issue? I've tried the Techron treatment with no success.
Will a computer reflash solve this issue? I'm hesitant to just go down this path since I have custom PCM programming, but this may be a better alternative than pulling the tanks.
Any input appreciated.
Thanks,
Rick
Old Feb 9, 2007 | 02:32 PM
Blown 346's Avatar
Blown 346
Thanks,
Rick
Does the needle seem stuck? Sometimes they can get stuck by being put on too much. You might want try and remove the needle and re install it.
Old Feb 9, 2007 | 02:42 PM
C5Longhorn's Avatar
C5Longhorn
I appreciate the suggestion, but I don't think its the needle because on startup, the needle will sweep the whole face of the gauge.
Any other responses, keep them coming.
Old Feb 9, 2007 | 02:48 PM
Barrier's Avatar
Barrier
I think this is one of the symptoms of the fuel sender problem. When I treat my fuel system with Techron the needle moves a little more towards the full mark, but it never goes all the way. I would rather continue the treatment then have it repaired. I just don't want to end up with other problems from the repair, always a possibility. Maybe this spring I'll tackle it myself.
Barrier
Old Feb 9, 2007 | 03:02 PM
C5Longhorn's Avatar
C5Longhorn
Mine hasn't improved yet. I'm going to keep trying Techron, but I'm not too optimistic its going to fix it.
What kind of labor expense is involved with replacing the sending unit?
Old Feb 9, 2007 | 03:15 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
drop the tank.
Old Feb 9, 2007 | 07:01 PM
C5Longhorn's Avatar
C5Longhorn
That is what I'm afraid.
Old Feb 9, 2007 | 07:42 PM
2blklt4's Avatar
2blklt4
Mine gege used to fluctuate...here`s what i did;
1) one can of Sea Foam when tank is half full then drive till empty
Problem Solved!
Old Feb 9, 2007 | 07:57 PM
C5Longhorn's Avatar
C5Longhorn
I'm going to try the seafoam because I have nothing to lose but I'm not expecting much with my problem.
Is Seafoam a different solution than Chevron Techron?
Old Feb 9, 2007 | 09:13 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Sea Foam: good sh.. stuff. Yes, it's different. Can't hurt. Good luck
Old Feb 10, 2007 | 01:51 AM
molson's Avatar
molson
there was a TSB about the gas filler neck......
It would cause the pump to shut off early..before the tank was actually full.
Found it...http://www.corvetteactioncenter.com/....php?qstId=542
One guy on here actually cut an inch or so off his original part and it fixed his problem
Old Feb 10, 2007 | 10:04 AM
mitchcole's Avatar
mitchcole
Originally Posted by Todd157k
drop the tank.
You don't actually have to drop the tank. Just the metal shielding in front of the rear tire.
Then drain the tank. (unscrew the plate from the tank. There's a reusable rubber/neoprene gasket that seals the cover plate to the tank.)
The sending unit, pump, piping etc are all on the back of the tank facing the rear tire. You have to take the tire off.
It's actually pretty easy to get to. The emptying of the tank is the biggest pain.
The worst part is the ridiculous cost of the new part. $287!!?!?!? Just for the sending unit.
Old Feb 10, 2007 | 10:16 AM
C5Longhorn's Avatar
C5Longhorn
Thank you both for the information. If there is a Service Bulletin, does that mean they will fix your vette even if its out of warranty?
Old Feb 10, 2007 | 11:47 AM
molson's Avatar
molson
No...a tsb is not a recall.
It's for the techs working on your car.
Old Feb 10, 2007 | 12:56 PM
Corvette Don's Avatar
Corvette Don
Problem Solved!
Did the exact same thing with great results
Old Feb 10, 2007 | 01:01 PM
C5Longhorn's Avatar
C5Longhorn
Thats what I was afraid of. I'm going to try the seafoam first.
To Different Fuel Gauge problem
