retainer clips
Old Feb 9, 2007 | 04:23 PM
jan-db's Avatar
jan-db
Default retainer clips
How do you remove the plastic retainer clips for the front bumper and cowl?
Old Feb 9, 2007 | 05:38 PM
99MAGKOOP's Avatar
99MAGKOOP
If there the one's I think your asking about, pull center pin and then the outer piece. Re-install in reverse.
Old Feb 9, 2007 | 08:00 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Get a really small flat head screw driver and lift the center pin out and then use your fingers or a pair of needle nose pliers to pull them out.
Old Feb 10, 2007 | 09:38 AM
jan-db's Avatar
jan-db
I got it. No problem. I just pushed up from underneath to separate the head from the washer and pulled them out with pliers. Thanks for the help.
To retainer clips
