Rebuild or turn-key
I've been tossing the idea around for a while, I know I should make some calls to some local shops. But, I'm just not too sure if I really want to do this. Like I said, just in the planning stages now.
Thanks for your help,
As for funds it's probably going to be a wash either way as you'll still want a new cam, set of cylinder heads, crank, pistons, rods, rings, bolts, etc.
I had a separate long block built so when I dropped off my car at the shop the motors could just be swapped (as the alternative can be a couple of months of waiting depending on the machine shop schedule, parts delays, etc).
