help with cat!
Old Feb 10, 2007 | 04:37 PM
blaplant's Avatar
blaplant
St. Jude Donor '12
Default help with cat!
how do you know when you need to replace the cat mine makes a pinging sound now i just put a cat back on it the borla stingers and now same driving style i get 3-5 miles less a gallon should i replace
Old Feb 10, 2007 | 08:09 PM
robert123's Avatar
robert123
If your cats are clogged and need replacing the car will not run good. Mine kept on stalling. If the car ran good prior to the catback install it is probably not the cats. Maybe you have the flows reversed on the mufflers.
