Oil pressure gauge topped off
Old Feb 10, 2007 | 08:08 PM
wreakhavoc's Avatar
wreakhavoc
Default Oil pressure gauge topped off
My oil pressure was showing 80 on the gauge and heads up display. I checked it on the dashboard info and it says 130.
What could be going on here?
Old Feb 10, 2007 | 08:25 PM
birch64's Avatar
birch64
oil pressure sensor. I been through 6
http://forums.corvetteforum.com/show....php?t=1617219
Old Feb 10, 2007 | 09:50 PM
Oldvetter's Avatar
Oldvetter
Turn ignition on, engine off, if you show oil pressure your oil pressure sensor is bad. It is located at the back, under the intake manifold. Youy can DIY, about 2 hour job the first time. Search for instructions. Can cost up to $400 to have others do it.
Often the new sensors go bad. There is a "sticky" about relocating the sensor for easier future replacement.
There is another option, remove the wiper panel and cut a hole in body under it, easy access to sensor.
Old Feb 10, 2007 | 10:04 PM
N0TDADYS_98's Avatar
N0TDADYS_98
2nd option is probably the best IMO....
Old Feb 11, 2007 | 12:08 PM
wreakhavoc's Avatar
wreakhavoc
I've said it before and I'll say it again- this is the best forum I've ever seen. Thanks to all. I just read that whole "sticky" on this subject. What a wealth of information! I'm going to get the brass Buick sensor & 1/4 to 1/8 inch adaptor and do the hole cutting method.
Old Feb 12, 2007 | 03:17 AM
striper's Avatar
striper
I had the sensor go bad on my previous C5, a '98, and it was a PITA job the first time doing it. I'm sure if I had to do it again I could do it faster the next time. Today I was removing my wiper panel and after removing it I wondered why a hole for access to the sensor couldn't be cut if I need to do this job again. Apparently from this original post you can do that. It'd be a lot easier to do that than removing the intake manifold again. Why GM didn't just relocate the sensor to a more accessible location is beyond me. BTW, I had to remove the panel because I need to have my windshield replaced since a rock did some severe damage upon hitting it driving this past Friday.
Old Feb 12, 2007 | 11:48 AM
wreakhavoc's Avatar
wreakhavoc
I see from http://forums.corvetteforum.com/show....php?t=1472249
that there is a good aftermarket sensor available-
Standard Motor Products part number PS308
I'm going to see if any retailers around here carry their stuff.
To Oil pressure gauge topped off
