C5 head light in open position....
Old Feb 11, 2007 | 11:57 AM
RNEdelen's Avatar
RNEdelen
3rd Gear
Default C5 head light in open position....
Can you manually close a head light that is in the open position? My passenger side head light will not close. I have a stripped motor.
Old Feb 11, 2007 | 01:20 PM
Dennis Wilson's Avatar
Dennis Wilson
Yes, there`s a **** to turn. The owner`s manual tells how to do it.
Old Feb 11, 2007 | 01:50 PM
RNEdelen's Avatar
RNEdelen
3rd Gear
if it is the **** at the top of the assembly - this does not work. the **** turn freely but no movement of the head light assembly.
Old Feb 11, 2007 | 09:54 PM
Dennis Wilson
Its right at the top inside corner of the headlight cover, Has a rubber cover that you pull off & **** is under that. If it doesn`t work there must be something broken . Good luck!
Old Feb 11, 2007 | 10:02 PM
Itallian33's Avatar
Itallian33
That **** should be attached to the gear, so you might need to replace that. I know there is a post in the general sticky about it.
To C5 head light in open position....
