help understanding codes
Old Feb 11, 2007 | 12:54 PM
terrystoy1's Avatar
terrystoy1
Default help understanding codes
My 98 coupe was running very bad cutting out but not throwing any codes. Took it to a mechanic and he replaced a bad coil. While it was in the shop, I had him go head and replace the oil sending unit becase the gage was pegged to the max. He replaced this and had to remove the intake and replaced the intake gasket. when I picked it up it ran fine for the mile trip back to my garage. I started it last night and drove it about 20 miles and the check engine light came on. When I got home I checked the codes and found the following codes. P0113 C and P1111 HC. I looked them up and found out it was high voltage detected in the intake air sensor. What the heck does that mean? and any theories on to how to fix it. Thanks in advance for any help you can lend.
Old Feb 11, 2007 | 02:00 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Check the sensor, did he plug it back in? Break the wires? Etc
Old Feb 11, 2007 | 08:52 PM
terrystoy1's Avatar
terrystoy1
all wires look good and plugged in.
To help understanding codes
