How to check fuel pump?
1. When I turn on the key should I hear the pump start? (I don't hear anything, quite as a mouse)
2. Is there an easy way to tell if I am getting fuel to the engine when I turn the key on?
thanks
thanks
You can dis connect the fuel line from the fuel rail ( the braided line). You will need a quick dis connect tool for that. Once that line is off, I would have a bowl or something similar under the line. Turn the ignition to power accessory, if you dont have fuel coming out of the line the pump is dead.
If it is quite, it could be a bad pump or bad fuse/relay. Check the cheapest and easiest item first.
I would def check for fuel pressure and volume. if it's 0 I would check the relay make sure we have power and ground where we need it, and make sure there is power and ground at the pump before condeming it.
as said usually you can hear them, if you just turn the key on but not to crank it should come on for about 2 seconds to prime the system.
-=Rick
