Amoco 93 vs. Sunoco 94 - Sorry CA :(
Old Oct 6, 2001 | 09:58 AM
DAP's Avatar
DAP
Default Amoco 93 vs. Sunoco 94 - Sorry CA :(
Amoco 93 vs. Sunoco 94. Which do you prefer-and why if you can name the differences...
I recently read anytime you add 5-8 more gallons of gas, the PCU resets it's curve to time for 94 octane, and than backs off as needed. Myth?
I can understand age and quality of gas vary, but so does everything in these d@@mn things...
Old Oct 6, 2001 | 10:20 AM
Sniper168gr's Avatar
Sniper168gr
Default Re: Amoco 93 vs. Sunoco 94 - Sorry CA :( (DAP)
DAP - Friend of mine owns an Amoco and claims that their refinement process is better than Sunoco. Even though the octane reported maybe higer by Sunoco, he calims that Amoco fuel runs cleaner and hotter. So he claims... :confused:
I run Amoco. Why? Because the Sunoco dealer's lot is real small, always crowded and the Amoco is closer! :D
Old Oct 6, 2001 | 10:44 AM
Jim Kramer's Avatar
Jim Kramer
no contest here - we don't have Sunoco in Tampa, Florida! :D
Old Oct 6, 2001 | 11:31 AM
CRUZMISL's Avatar
CRUZMISL
Default Re: Amoco 93 vs. Sunoco 94 - Sorry CA :( (VetteMan2k1)
I always run Sunco 94 because there are no Amoco's in Canada. When I'm in Michigan though I will fill up at an Amoco because the 94 is a fortune in comparison. Personally if one was next to the other I would fill up at either, both good quality.
Joe
Old Oct 6, 2001 | 04:41 PM
DAP's Avatar
DAP
Default Re: Amoco 93 vs. Sunoco 94 - Sorry CA :( (CRUZMISL)
Any of you heard that PCM re-read upon shut down and seeing a few more gallons?
Old Oct 6, 2001 | 05:18 PM
97silverbullet's Avatar
97silverbullet
My Vette only runs on Sunoco Ultra 94. :smash:
Old Oct 6, 2001 | 05:27 PM
MDL-01C5's Avatar
MDL-01C5
Default Re: Amoco 93 vs. Sunoco 94 - Sorry CA :( (97silverbullet)
I heard somewhere, too, that Amoco was superior quality. I cannot compare it to Sunoco, however, because that chain doesn't exist in this part of the state. I exclusively use Amoco Ultimate 93, and have been very happy with it
Old Oct 6, 2001 | 07:14 PM
YO-EL's Avatar
YO-EL
Default Re: Amoco 93 vs. Sunoco 94 - Sorry CA :( (MDL-01C5)
Amoco 93 and I'll tell you why...
Sunoco contains "methanol" which I have been told is not too good for your engine. I have heard that numerous times, so I'm staying away from fuel that contain methanol. Amoco does not use it.
Old Oct 6, 2001 | 07:47 PM
DaveP's Avatar
DaveP
At least in Mi SOME Sunoco fuel has ETHANOL, not methanol. I avoid those sunoco stations, it says right on the pump if they use it. Either -OH group has lower BTU output than gas. I use an alternating mix of amoco, sunoco, mobil and shell. Been told all have various levels of different additive packages, and by alternating fuel brands you gain the advantage of some additive effectiveness from every type/brand. If I go to the track, I'll try to use the highest octane, 94, sunoco.
Old Oct 7, 2001 | 01:43 AM
DAP's Avatar
DAP
Default Re: Amoco 93 vs. Sunoco 94 - Sorry CA :( (DaveP)
Hmmm....a dead heat? :boxing
Old Oct 7, 2001 | 05:33 AM
c5magred2's Avatar
c5magred2
i love the way my c5 responds to the clear amoco ultimate.ultimate is the only fuel that has been in my tanks. :seeya
Old Oct 7, 2001 | 11:15 AM
LT1GMC's Avatar
LT1GMC
The BEST reason to use AMOCO,93/the Ultimate/crystal clear/ is just that: Amoco 93 is the Only automobile gas in U.S. that is CLEAR, no dye, so what that means is you know when you look at it that it is really the good 93 stuff, and not something else(regular, low grade) pumped in the premium tank. Now while getting regular instead of premium is only a pain for most Vette drivers, guys with supercharged cars, or modified Waverunners , HAVE to have the real premium.
To Amoco 93 vs. Sunoco 94 - Sorry CA :(
