Gauge pod - wire routing
Old Feb 12, 2007 | 09:21 AM
clutchman's Avatar
clutchman
Default Gauge pod - wire routing
How about someone chiming in on their gauge install. Where did you run the wires through the firewall? Any tips?
Old Feb 12, 2007 | 07:50 PM
Yellow03Z06's Avatar
Yellow03Z06
I ran the wires thru the hood latch cable grommet on the drivers side. get a hanger and fish it thru with that. Under the hood, I removed the wiper fluid tank for more room. Good luck!
Old Feb 12, 2007 | 09:14 PM
clutchman's Avatar
clutchman
Thanks!
Old Feb 12, 2007 | 09:47 PM
clutchman's Avatar
clutchman
While we're on it, where did you pick up the 12 V light power?
Thanks a ton
MN
Old Feb 13, 2007 | 12:33 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
i ran mine across the dash to the passenger side and then from there went through the grommet with the wiring harness.
Old Feb 13, 2007 | 03:21 PM
clutchman's Avatar
clutchman
Excellent thanks guys.
MN
To Gauge pod - wire routing
