Trans. Troubles After POwerloading?
Old Oct 6, 2001 | 10:45 AM
Mitch C's Avatar
Mitch C
Default Trans. Troubles After POwerloading?
With the removal of torque management and the quicker shifts with the Powerloader. I was wondering if anyone has had any transmission troubles with their A4s.
1998 Metalic Purple A4 Coupe
Powerloaded
Donaldson Blackwing
172 Stat
3.15 axle
[Modified by Mitch C, 8:48 AM 10/6/2001]
Old Oct 6, 2001 | 10:53 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Trans. Troubles After POwerloading? (Mitch C)
too early to tell for me...only 2 days :D
Old Oct 6, 2001 | 11:47 AM
chuckster's Avatar
chuckster
Actually, snappier shifts increase the life of the transmission. The manufaturers make em soft and lazy for comfort to the average driver.
But Vette owners are not the average driver!
Snap on!!! :D
Old Oct 6, 2001 | 02:48 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Trans. Troubles After POwerloading? (chuckster)
None here
RG
Old Oct 6, 2001 | 02:54 PM
Austrian Vette's Avatar
Austrian Vette
What is it good for to remove the torque management????
Michael
Old Oct 6, 2001 | 04:32 PM
SRitger's Avatar
SRitger
Cruise-In I Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
I've had mine Powerloaded for almost a year now, and drive it pretty hard (including some drag strip time), with ZERO problems...except for increased tire wear! :D
Cheers,
Steve
Old Oct 6, 2001 | 06:43 PM
Sully C5's Avatar
Sully C5
No tranny problems at all.
Old Oct 6, 2001 | 07:14 PM
team-zr1's Avatar
team-zr1
Default Re: Trans. Troubles After POwerloading? (Austrian Vette)
Michael
If the TCC is either not working correctly or as in the following PCM trace shows, the TCC code was mucked with by a so called PCM tuner, the Torque management circuit to protect the drivetrain will disengage the converter to where your free wheeling ( T.C not connected to drivetrain) thus you lose overall torque since it is not under engine power.
The attached Excel sheet is from a trace with a A4 C5 owner who has had lose of performance since he has PCM code worked on.
He felt the car just did not pull very well. He did a PCM scan while driving and the results for this tread was sorted to bring all the cycles the TCC was engaged to the top of sheet showing loss of torque.
http://teamzr1.com/torqmange.html
Notice this occured during different RPMs.
Now here is a trace that was during WOT and TCC not being triggered.
Notice the higer overall TQ number.
http://teamzr1.com/wottq.html
[Modified by team-zr1, 3:39 PM 10/6/2001]
Old Oct 6, 2001 | 08:40 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Trans. Troubles After POwerloading? (team-zr1)
Michael
I'm no medicine man, so give to me straight Doc....is the PLII good or bad....cause I noticed a very big difference to the plus side :D
Old Oct 6, 2001 | 10:01 PM
Mystery Fan's Avatar
Mystery Fan
Default Re: Trans. Troubles After POwerloading? (Mean Green 2000)
Mean Green,
I think the point that Zr-1 is trying to make is that the PLII is not optimally perfect for a given application. Unless, you have a PCM custom made and dyno tested for your particular application, you will never have it PERFECT. From what I can tell, his experience was less than ours with Steve Cole's Powerloader II. Personally, I am pleased with the less than perfect results that my car has achieved with the PLII. It is so much closer to being perfect than it was.
Thanks you Mr. Cole....The masses are enjoying your products and the smiles that it brings!
[Modified by Mystery Fan, 8:03 PM 10/6/2001]
Old Oct 6, 2001 | 10:25 PM
Mike Siska's Avatar
Mike Siska
Mine has been in for three months and 3500 miles. No problems other than tire wear, a bigger smile I can't get off my face :D a slight decrease in gas mileage (you hold down the right pedal all the time and see if your gas mileage doesn't decline :lol: :lol: ), the active handling seems to activate more often, and a faster trip down the drag strip :cheers: :cheers: :lol: :lol: :lol: :lol:
Old Oct 6, 2001 | 10:47 PM
team-zr1's Avatar
team-zr1
My point was not to any one brand of custom coder but that the TCC (Torque Convertor Clutch) circuit should be considered when tuning or if it has any ill effect to maximum performance as well as the Crankshaft Position Sensor (CKP) and knock sensors.
Torque management seems to be forgotten and then people do not understand why after having the A4 re-calibrated that they feel the car is not pulling as well as it should.
Other factors could trip off the TCC such as multi misfires, unknown to the end user and thus I always suggest people hooking up a PCM scanner and finding out if their mods ( which includes PCM coding) have an ill effect to TCC and if it does, have their PCM coder correct the problem.
I am not saying to turn off TCC monitor just tune it not to undo the performance gains..
Old Oct 6, 2001 | 10:54 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
thanks...looks like I have a lot to lean yet..... :cheers:
is a pcm scanner something like autotap...?
Old Oct 6, 2001 | 11:07 PM
team-zr1's Avatar
team-zr1
Yes or a Ease powertrain scanner. With a tool like this you can collect all the information about the drivetrain while your driving and know exactly how all the functions are performing. You'll be able to know when the TCC has been tripped and if it has effected your performance.
Using a scanner is quite easy and you'll know how well or poor your tuned for performance is without having to wonder.
Old Oct 6, 2001 | 11:18 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
^^^^ thanks again...any reccomendations on one or the other, can they both monitor the stuff you mentioned?
Old Oct 7, 2001 | 04:35 AM
Austrian Vette
team-zr1,
I wonder if my problem has something to do with the torque management??
My TC often unlocks when I am in 4th and cruise under 2000rpm, then it sometimes locks up again, soemtimes does not.
If it does not, I have to stop and turn off the car, when I start again every thing works well, until I come under 2000rpm in 4th durig cruissing again.
Sometimes it throws the 1870 code then and I´ve seen a 0748???(not sure) code (something with a solenoid) sometimes also. Then I have to clear the codes with AUTOTAP to get the TC lockup again.
No problems in 3rd!!!
That all came after the tranny, 3.42 and TC swap.
I have a vacuum module controlling the shift firmness.
It may be the Hypertech also as I set the tirehight and gears with that??
Hope to find out what it is?!?!?!?!?
Maybe you have an idea?!?!?!?
Thanks,
Michael
Old Oct 7, 2001 | 10:39 AM
team-zr1's Avatar
team-zr1
It just might be a problem and the best thing I can suggest is you do some PCM scanning which includes Delivered Torque as one of the functions you monitor and see when TCC is on or off.
Your welcome to e-mail me copies of your traces and I'll let you know what I see.
John
team-zr1,
Thanks,
Michael
Old Oct 7, 2001 | 12:02 PM
Austrian Vette
Thanks, I´ll come back to your offer when I get my laptop back from my brother and when I figured out how to save and/or print the AUTOTAP datas.
What all things should I scan???
thanks,
Michael
Old Oct 7, 2001 | 12:41 PM
TLewis4095's Avatar
TLewis4095
Default Re: Trans. Troubles After POwerloading? (Mystery Fan)
Quote:I think the point that Zr-1 is trying to make is that the PLII is not optimally perfect for a given application. Unless, you have a PCM custom made and dyno tested for your particular application, you will never have it PERFECT. From what I can tell, his experience was less than ours with Steve Cole's Powerloader II. Personally, I am pleased with the less than perfect results that my car has achieved with the PLII. It is so much closer to being perfect than it was.: Quote
Anytime line pressure is increased in an auto tranny the clutch disc's have increased life from less slippage and friction generated heat. :yesnod:
To Trans. Troubles After POwerloading?
