Check engine light won't work (at all)
Old Feb 12, 2007 | 02:23 PM
Truman's Avatar
Truman
2nd Gear
Default Check engine light won't work (at all)
Hi everybody,
I have a 2002 Vette, and the CEL came on last week, so I took it to AutoZone. They asked me if I wanted the light turned off, so I said, "Sure". I didn't realize they meant PERMANENTLY! It doesn't even come on during the crank-up "self-test" when all the other dash lights do.
Is there a way to get it back on via the DIC, in case there is another problem in the future? My active code is P1416, and there were almost 20 H codes in memory, but it has been wrecked in the past.
BTW, I didn't know about the code reading capability on the dash until AFTER I went up there and they hooked up their Actron.
Thanks,
- Truman
Old Feb 13, 2007 | 01:13 AM
PierEagle's Avatar
PierEagle
Originally Posted by Truman
Hi everybody,
Thanks,
Other than a burned-out bulb I wasn't aware that you could disable the SEL. Maybe Bill Curlee will jump in and shed some "light" on that one. One thing I've noticed reading a lot of the posts, either people don't get or if they have one, don't read the Owners Manual. There is a bunch of good info in there i.e., reading DIC codes, calibrating the TPS, maintenance specs, etc.. If you don't have one they can be purchased from www.HelmInc.com. They are the official printers.
Cheers
Old Feb 13, 2007 | 10:15 AM
dougbfresh's Avatar
dougbfresh
You can't turn it off permanently, if it does not come on you have a wiring or a bulb issue.
Old Feb 13, 2007 | 10:23 AM
jfrc's Avatar
jfrc
your lucky
mines on all the time
Old Feb 13, 2007 | 10:31 AM
dougbfresh's Avatar
dougbfresh
Depending on the state, on or off all the time will fail emissions test.
Old Feb 13, 2007 | 11:34 AM
Truman's Avatar
Truman
2nd Gear
Default It's back
I guess it was a fluke. It started working again when I cranked it up to go home yesterday. The wonderful world of computers...
Old Feb 13, 2007 | 06:27 PM
HollywoodFRC's Avatar
HollywoodFRC
Default These cars are haunted
First cold day in a while, started the car, orange security light remained on. Stopped car, restarted, security light went out. Checked DTC, no codes. Now it behaves normally. Never occured again. Crazy!
Old Feb 14, 2007 | 12:10 PM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
I have an Actron. It will read and reset codes, but it does not turn off the capability like you can with tuning software.
To Check engine light won't work (at all)
