Where do you guys have your raptor shift light located. I did a search and did not find anything. I did find something about a dual shift light with a launch light made it to it. To bad I already have this one.
If you are pretty comfortable dissasembling your car you can remove the dash pad and install it in one of the AC vents. I don't have the raptor but I will be getting a led shift light installed in the vent.
I have mine mounted on the steering column in an area that doesn't cover any of the dash gauges. Look at the picture above and my Raptor is placed just about in between the 200 mph on the speedo and the DIC text.
