F45 Simulators
Feb 13, 2007 | 01:44 AM
F45 Simulators
I am replacing my F45 shocks with 06 Z06 shocks and have ordered the F45 simulators. There are 8 in the kit. 4 go on the ends of the plugs that usually connect to the shock actuator wires. Where do the other 4 go? On the ride height sensors? And if so, what do the right height sensors do to the F45 shocks as the height changes?
thanks mtr
Feb 13, 2007 | 12:20 PM
Feb 13, 2007 | 06:20 PM
Why not just turn off the F45 with the Tech II?
Cleaner, and save yourself the money.
Feb 13, 2007 | 06:33 PM
That is not an option with the early C5's, like my '98! Not sure which year they changed the ECM to be able to use the TEC II.
Feb 13, 2007 | 07:19 PM
Quote:
Originally Posted by
fixvet
His is a 2000 (I checked), mine is a 2000.
It worked on mine, so, I assume it would work on his.
But, then, you never know.
Feb 13, 2007 | 07:38 PM
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
i have to do the same to mine when i upgrade my shocks this year
Feb 13, 2007 | 07:55 PM
Cool! Maybe it's just the 97's & 98's that need the sims! My F45's are still working great, but I know I'll be facing a change some day and have been trying to do my homework before then. I like the adjustable feature, but could never afford new F45 shocks.......not without winning the lottery first!
I'm always looking for a definitive answer on this procedure for a '98 C5. I'll keep lurking!!
Feb 13, 2007 | 09:26 PM
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
From the digging around I've done, on 99+ cars the F45 is deletable in the BCM by using a Tech II. It's apparently hit or miss in the earlier ones.
Feb 13, 2007 | 10:17 PM
fixvet
....I'm always looking for a definitive answer on this procedure for a '98 C5. I'll keep lurking!!
Fastbird93
Well, there's your "definitive" answer then.....
Feb 14, 2007 | 09:14 AM
Cruise-In VII Veteran
there is another recent thread on this, 4DRUSH simply unplugged the rtd module out back and had no problems, I have not tested this yet
http://forums.corvetteforum.com/show...+BCM+Procedure
Feb 14, 2007 | 02:06 PM
Anyone got a F45 drivers shock in good condition? I need the rubber bushing for the lower part of the shock
