Help with definitions.
Old Feb 13, 2007 | 01:15 PM
67L36Driver's Avatar
67L36Driver
Default Help with definitions.
Been lurking to learn about C5s and am having trouble with some of the short hand. Can someone fill in the blanks?
NBM....?
FRC.....?
CEL.....?
HUD = heads up display..?
STI...?
DIC...?
TPS = throttle position sensor ..?
HID...?
DTC....?
TSB = technical service bullitin..?
ECL....?
PCM = powertrain control module ..?
CLB.....?
Just trying to be better informed if I go shopping for a new(er) vet.
TIA = Thanks in advance fellas.
Old Feb 13, 2007 | 03:27 PM
03QSLVRZ06's Avatar
03QSLVRZ06
NBM....? Navy Blue Metallic
FRC.....? Fixed Roof Coupe / Fast Race Car
CEL.....?
STI...?
DIC...?
TPS = throttle position sensor ..? Tire Pressure Sensor
HID...?
DTC....?
ECL....?
CLB.....? Column Lock Bypass
Old Feb 13, 2007 | 03:33 PM
Tmyz 2K's Avatar
Tmyz 2K
NBM....? navy blue metallic
FRC.....? fixed roof coupe
CEL.....? check engine light
STI...? suburu has a wrx sti where did you see this?
DIC...? digital instrument cluster
HID...? high intensity display (headlights)
DTC....? diagnostic trouble code
ECL....? electronic column lock
CLB.....? column lock bypass
Old Feb 13, 2007 | 03:53 PM
IFLUBYU's Avatar
IFLUBYU
FRC.....? Fixed Roof Coupe (99-00), Z06 (01-04),
(some people also use this to refer to the plastic covers over the coil packs, wrongly)
CEL.....? CHeck engine light
STI...? Sh!+ Talking Idiot (j/k!)
DIC...? Driver Information Center
TPS = Tire Pressure Sensor
HID...? High Intensity D... (really bright headlights)
DTC....? Diagnostic Trouble Code
ECL....? Electronic Column Lock
CLB.....Column Lock Bypass,
BSM: Body Side Molding
TIA = Thanks in advance fellas.[/QUOTE]
Old Feb 13, 2007 | 04:25 PM
67L36Driver
Default A few more.
CAGS.....? something to do with up shifting a manual trans.
DTE....?
A4...? a particular automatic trans?
TAC...?
BCM...?
Never saw that one on the C1-C2 forum.
Old Feb 13, 2007 | 05:31 PM
IFLUBYU's Avatar
IFLUBYU
CAGS. Computer Aided Gear Selection otherwise known as "skip-shift".
DTE....Dyno Tech Engineering (known for rears, do a wide range of performance products/services)
A4...? a particular automatic trans? Stock Auto tranny for C5s
TAC...?
BCM...? Body Control Module
(not to be mixed up for the EBCM, Electronic Brake Conrtol Module)
To Help with definitions.
