Code Question
Old Feb 15, 2007 | 10:18 AM
Hawkdriver's Avatar
Hawkdriver
Default Code Question
Replaced my harmonic balancer and now am getting TCS codes 1283 and 1288. These are not on my code list....Anyone have a clue 'cause I don't?!
Old Feb 15, 2007 | 11:00 AM
87SAM's Avatar
87SAM
C1283 Excessive Time to Center Steering
C1288 Steering Sensor Circuit Malfunction
According to: http://www.digitalcorvettes.com/foru...ad.php?t=45539 for 98 anyway
Old Feb 15, 2007 | 03:06 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
When you removed the rack & pinion unit you allowed the steering wheel to rotate, now the steering wheel position sensor needs to be nulled.
This has to be done with a Tech II.
Old Feb 15, 2007 | 03:24 PM
Hawkdriver's Avatar
Hawkdriver
Thanks! Next question is what is a Tech II?
Old Feb 15, 2007 | 03:46 PM
Jeffs FRC's Avatar
Jeffs FRC
A tech II is basically the scanner GM techs use to reflash your computer and pull codes and what not.
You need to visit the dealer.
Old Feb 16, 2007 | 07:33 AM
Hawkdriver's Avatar
Hawkdriver
Thanks Jeff! Kit is still doing great! Next is headers I believe.
To Code Question
